68 valiant signet 2 door
Mopars For sale
so after almost 4 years building the valiant i have the opportunity to buy a bucket list car so it has to go. it's a 2 door car and being the signet has lots of extra stainless and chrome. specs as follows.......
318 v8, solid lifter cam, adjustable rockers, edelbrock tr5 tunnel ram with dual holley carbs, mickey t valve covers, new stainless headers, new full dual exhaust (summit), recored big block radiator, all new hoses (coolant and ethanol safe fuel) new mr gasket air filters, new glass fuel filters, new mopar orange ignition box and coil, mopar a833 4 speed manual gearbox with hurst competition plus shifter, recent clutch, new amd 4 speed hump for tunnel, new pedal bushings and rubber pedal pads, rose jointed clutch linkage, new speedo drive gear (on way from brewers in the us) to correct speedo, hybrid propshaft, ford explorer rear axle shortened 3" with disc brakes, 31 spline shafts and lsd, new mopar super stock leaf springs with new poly bushes, 8.5x15 rear slot mags with new 295 50 15 tyres, 5.5x15 slot mags with new 165 15 tyres, recent new fuel tank and sender (gauge works), mercedes black leather front and rear seats, new black carpet set, new black door armrests, new black dash cap/skin (bond over cracked original), 70's superior wood rim steering wheel with new boss and horn kit, new interior light lens, good headliner with no rips/cuts, new lock and key set fitted, new upper and lower front ball joints fitted, poly bushes for upper and lower wishbones (not fitted but here), new screen washer bag/pump fitted, both as new front wings (same as plymouth duster) and both as new doors (with all mechanisms and glass) supplied. i still have the brake servo and bracketry if you want it. i've got lots of pics of all of the build if you want any more.
there's probably more i've forgotten. just ask.
as close to 15k ono as i can get or i'll just keep it and carry on
cheers, neil.
07718 339011.
IMG_0001 (1).JPG (136.46 KiB) Viewed 554 times
IMG_0002 (1).JPG (128.06 KiB) Viewed 554 times
IMG_0003 (1).JPG (89.54 KiB) Viewed 554 times
IMG_0004 (1).JPG (89.87 KiB) Viewed 554 times
IMG_0005 (1).JPG (81.69 KiB) Viewed 554 times
IMG_0006 (1).JPG (143.27 KiB) Viewed 554 times
Re: 68 valiant signet 2 door
Well, I did not see that coming! :shock:
What is the "Bucket List" car then????
a '50 mercury :thumbright:
i don't want to sell the valiant but can't afford both. i've wanted a 49-51 merc' for must be almost 40 years so.....
Turning to the dark side, young Skywalker??
How will we survive without all your fascinating and innovative updates???
isn't there a blasphemers or non mopar section for members who diversify? ;)
edit.... found it.... 'alternative muscle'
if it comes together i'll be lurking there with the new build :thumbright:
Oooooo a Mercury, love one myself so can't blame you for that :salute:
ScottyDave wrote: Thu Aug 12, 21 10:55 pm Oooooo a Mercury, love one myself so can't blame you for that :salute:
thanks, the wife said what's one of them? i said you know the pharaoh's car in american graffiti? it's like that. she knew too :thumbright:
bump
