Dom's 66 Coronet 500
Re: Dom's 66 Coronet 500
So I cleaned up the chrome trim strips and fitted them and yes, pretty happy with that :)
Floor 83.jpg (78.03 KiB) Viewed 10539 times
Really like that, it’s all in the details.
that looks great, i'd be well happy with that. :thumbright:
on those tv programs they steam the trim and it tightens it up. if you have one of those handheld steam cleaners maybe give it a go?
Wow, that’s really finished it off well! 8-)
Great job there. =D>
mygasser wrote: Tue May 07, 24 11:00 am that looks great, i'd be well happy with that. :thumbright:
Depends what the material is, mostly plastic and it doesn’t work. That used to be the trick with headliners, whatever it is that they make them from these days steaming does nothing.
Yes that looks real good and well done :thumbright:
Well done, very professional looking.
So, armrests... The originals are pretty awful, distorted with crumbling foam. So I've carved out some new ones from some wood I had lying around. Now bear with me here, I think they'll look alright once they get covered....remains to be seen though :?
Floor 84.jpg (136.09 KiB) Viewed 10366 times
I turned up a set of mounting bobbins for them nonetheless.
Floor 85.jpg (127.04 KiB) Viewed 10366 times
And fitted them to the already prepared rear mounting plate thingys.
Floor 86.jpg (105.34 KiB) Viewed 10366 times
The completed panels (sans armrests for now) do look much better...
Floor 87.jpg (79.97 KiB) Viewed 10366 times
And mean I have finally replaced the rear seats and belts, a big move forward :)
Floor 88.jpg (67.9 KiB) Viewed 10366 times
I can see where you are headed, nicely stitched covers and you have some sharp looking armrests.
Work has been getting in the way of work again... I have managed to wrap the armrests though, I think they'll look OK. Still have the front door cards to make.
Floor 89.jpg (122.11 KiB) Viewed 10226 times
Very professional looking, well done. =D>
Derek wrote: Mon May 27, 24 12:24 pm Very professional looking, well done. =D>
agreed, very nice work. don't doubt your abilities when your work is this good.
Spot on!
Looks good to me. :thumbright:
No, I still haven't quite finished mounting up the bits yet, but in case this is of use to anyone, I was missing a large number of the original Door Card mounting clips. I took a punt on a bag of these, which are generally available online:
And they work fine, same panel thickness, door hole size etc.
