Floyd Brothers 70 Challenger
Nice job Stu
- Stu
Being as it was all going so well, thought it was about time to pull it all apart again…
- IMG_1659.jpeg (197.44 KiB) Viewed 38257 times
- IMG_1660.jpeg (219.39 KiB) Viewed 38257 times
- IMG_1661.jpeg (185.72 KiB) Viewed 38257 times
- IMG_1652.jpeg (222.84 KiB) Viewed 38257 times
full respray or new vinyl top? i assumed the latter until i noticed the side trim was also removed.
That looks in pretty good condition!!!
- Stu
Full respray and new top. About time to get rid of the crap paint job and cracking filler.mygasser wrote: Sat Oct 11, 25 1:57 pm full respray or new vinyl top? i assumed the latter until i noticed the side trim was also removed.
- Stu
It’s not too bad, apart from the rear centre of the roof, which has been badly filled instead of straightened out.
- IMG_1664.jpeg (171.35 KiB) Viewed 38234 times
cool, will you paint the roof anyway and then decide if it's getting a new vinyl top? at least then the roof's fully painted/protected if it does go under new vinyl.
- Stu
It’s definitely getting a new top, I already have it. I know they divide opinion and some aren’t keen, but I like them.
As for the paint, I had factored in panting it and then adding the roof, for the same reason, but I’m talking to some classic car companies in the area about it, as I only want this done once and right. I’m told that the adhesive won’t take if not done correctly and the last thing I want is moisture trapping.
yes it's definately not nice sanding fresh paint so the glue sticks for sure
- Stu
Slowly but surely turning it into a pile of parts again and finding the biggest problem areas.
- IMG_1699.jpeg (243.43 KiB) Viewed 37226 times
- IMG_1698.jpeg (232.38 KiB) Viewed 37226 times
- IMG_1666.jpeg (106.85 KiB) Viewed 37226 times
- IMG_1665.jpeg (99.38 KiB) Viewed 37226 times
- IMG_1599.jpeg (161.67 KiB) Viewed 37226 times
- IMG_1597.jpeg (140.04 KiB) Viewed 37226 times
- IMG_1596.jpeg (195.02 KiB) Viewed 37226 times
- Stu
I should probably update, as there has been a lot going on.
The short version is, the roof was not in good condition at all, despite looking like it wasn't too bad.
Never seen bodgery like it. It had not only had a replacement wonky centre section badly welded in, but the welding was complimented by what looked like a mix of filler and sealant, before being brush painted over from inside and sprayed over from outside. Further enhanced by strips of untreated steel being hammed into gaps and sealed in to bolster it, it was an absolute disaster.
After very little thinking at all, it was decided that I will have to park the new engine build and do this properly instead, so finished stripping it, had it epoxy primered and pushed it round the corner to a proper welder to start patching what we already knew about whilst I emptied my wallet for a new roof skin...
Some random pics of the early patching taking shape and a sample of the multi-patch grot that was cut out of one of the rear quarters...
- 1. Early patch repairs.JPEG (42.28 KiB) Viewed 31471 times
- 2. Early patch repairs.JPEG (104.4 KiB) Viewed 31471 times
- 3. Early patch repairs.JPEG (114.48 KiB) Viewed 31471 times
- 4. Early patch repairs.JPEG (101.42 KiB) Viewed 31471 times
- 5. Early patch repairs.JPEG (109.23 KiB) Viewed 31471 times
- 6. Early trunk repairs.JPEG (94.73 KiB) Viewed 31471 times
- 7. Patches on patches and rot removed.JPEG (94.02 KiB) Viewed 31471 times
- Stu
While that was going on, Chris Goodale managed to get me a roof skin, outer roof rails and drip rails in double quick time! Epic service as ever.
8 hour roadtrip in a van later and the new skin was flopped on top for a quick check before bracing and cutting began.
- 8. New Roof Panel.JPEG (84.39 KiB) Viewed 31466 times
- 9. Outer roof rails and drip rails.JPEG (111.67 KiB) Viewed 31466 times
- 10. New Roof Panel Check Fit 2.JPEG (118.26 KiB) Viewed 31466 times
- 11. New Roof Panel Check Fit.JPEG (109.87 KiB) Viewed 31466 times
- Stu
From there it was a case of starting to dig out all the rot, brace the crap out of the car and cover my eyes while a much more competent welder than I removed the roofskin...
A selection of pictures for your delectation, of random holes, bodges, bracing and grinding. This was an arse-puckering point in proceedings for me.
- 12. Roof removal uncovering bodges.jpg (100.51 KiB) Viewed 31459 times
- 13. Roof removal uncovering bodges.jpg (110.96 KiB) Viewed 31459 times
- 14. Roof removal.jpg (103.25 KiB) Viewed 31459 times
- 15. Roof removal grot.jpg (95.33 KiB) Viewed 31459 times
- 16. Oles.jpg (111.91 KiB) Viewed 31459 times
- 17. Skin Off.jpg (138.51 KiB) Viewed 31459 times
- 18. Skin off Closer.jpg (143.34 KiB) Viewed 31459 times
- 19. Grot.jpg (115.15 KiB) Viewed 31459 times
- 20. More oles.jpg (112.85 KiB) Viewed 31459 times
- 21. Roof Off.jpg (123.1 KiB) Viewed 31459 times
- 22. Roof Off.JPEG (150.27 KiB) Viewed 31459 times
- 23.More.jpg (94.19 KiB) Viewed 31459 times
- 24. More still.jpg (118 KiB) Viewed 31459 times
- 25. Bracing.JPEG (131.67 KiB) Viewed 31459 times
- 26. More bracing.JPEG (126.5 KiB) Viewed 31459 times
- 27. Lead removal.JPEG (100.33 KiB) Viewed 31459 times
- 28. Oles and more oles.JPEG (117.24 KiB) Viewed 31459 times
- 29. Digging out more lead.JPEG (102.64 KiB) Viewed 31459 times
- 30. Cleaning up for cutting out.JPEG (135.81 KiB) Viewed 31459 times
- 31. Digging out bodgery.JPEG (100.37 KiB) Viewed 31459 times
- Stu
- 32. No comment.JPEG (106.39 KiB) Viewed 31481 times
