Blue's Barracuda
Re: Blue's Barracuda
I’m going to run it all in Teflon lined hose, less fittings needed and a much easier install than hard line, I did used to do it that way in the past though.
definately easier for sure. putting over a dozen bends in a 5m length of hardline was stressful i can tell you. one bend the wrong way and it would've been done and scrap.Blue wrote: Wed Aug 06, 25 3:50 pm I’m going to run it all in Teflon lined hose, less fittings needed and a much easier install than hard line, I did used to do it that way in the past though.
New tank is here and the sump has trimmed up nicely for a good fit. Tank needs bolting into the car next so I can mark where the fuel pump mount needs to go, position is critical so I can’t risk just measuring it.
- IMG_4021.jpeg (153.08 KiB) Viewed 14120 times
while you have a big hole in the bottom of the tank will you add any baffles either side of the new fuel 'well' to help keep fuel there all the time?
Rather than cut out the whole area I’ll just cut a couple of large holes in the bottom, that will act as baffle.
Blue wrote: Mon Aug 18, 25 10:05 am Rather than cut out the whole area I’ll just cut a couple of large holes in the bottom, that will act as baffle.
Tank cut and fuel pump mount location finalised.
- IMG_4030.jpeg (121.97 KiB) Viewed 14079 times
- IMG_4029.jpeg (134.98 KiB) Viewed 14079 times
Up at the sharp end is a large port mangnafuel billet regulator. A bit overkill for my application but I used the usual Hot Rodder’s reasoning for correct parts selection, “it was cheap and available” so it’s all good.
- IMG_4028.jpeg (214.56 KiB) Viewed 14079 times
- IMG_4027.jpeg (197.32 KiB) Viewed 14079 times
Bit of progress, correct size fittings in the pump and weatherproof connectors fitted, ready to install. Smaller fittings fitted to the regulator and new feed lines made. Can’t do anything else now until the tank goes in.
- IMG_4052.jpeg (172.81 KiB) Viewed 13991 times
- IMG_4053.jpeg (203.32 KiB) Viewed 13991 times
- IMG_4054.jpeg (216.8 KiB) Viewed 13991 times
The Red, Yellow and Blue are working there, not sure about the Purple though...
Yea if I’d had a choice purple wouldn’t have been it…
Paid a visit to Grace at Brooklands Today and had my sump and fuel pump mount tigged to my tank. Glad I didn’t try to MIG it myself, it didn’t weld easily due to the galvanising on the inside.
- IMG_4068.jpeg (162.13 KiB) Viewed 13939 times
it's nothing some careful masking and a can of satin black wouldn't fix though. with the black fittings the top half to match would look fine.
Who’s Grace and is that Brooklands museum?
Grace Roaf, she teaches apprentices at Brooklands museum, very skilled welder and metalworker. She also crews for Don Scott in NSS and the Undertaker funny car.
You do build some exceptionaly nice cars and your work is spot on, it’s great following your builds.
Thanks Del, I try to make it entertaining!
