we got all of the tyres removed from the torq thrust wheels today ready for the guy to collect them. i'll reuse the tyres on the slot mags once they've had a good polish. i won't know yet if the rears will clear the arches to roll it back over to my main garage by the house, if not we'll have to fit a couple of others to get that done. either way the new rear wheels will stick out of the arches so there'll be some radiusing to do, fine with me as i like that look. :thumbright:
as i'm so decisive and never change my mind...... i've swapped the 318 engine and box for a jensen 383 and 727. i know i know i bought all those 'goody' bits to make more power from the 318 but it's a small block and i'm building a gasser so it really should have a big block right? :thumbright: anyway it's a mate so i may also end up dealing the parts for..... well i don't know yet, lol. ;)
Turbo diesel next week?
Blue wrote: Wed Sep 03, 25 8:01 pm Turbo diesel next week?
:-k well you can get over 600hp from those 3.0 mercedes td engines...... but no :D
neil
the 10x15 slotmags arrived today, woohoo! we're that busy i haven't even unwrapped them :shock:
after chatting with my mate he didn't want to buy the 'goody bits' i'd collected for the 318 so we've decided not to swap.
me? indecisive? never ;)
further to that last post i just ordered big end and main bearings for my 318. as far as i know the engine's all stock inside so i got +30 pistons and i just ordered -30 ends and mains. i had a chat with ash' when he dropped his/my freshly cleaned fe block to build for his zephyr and we decided if my 318 was getting a rebore, cam/lifters, timing set, oil pump etc i'd be better off getting the crank' reground rather than cheaping out and just fitting new stock bearings. the reason for going -30 not first undersize at -10 was a) price as the -30 mains were half the price and b) just in case it's ever had a 'grind i don't know about. anyway it means i can pull it apart whenever i want and get the block and crank' to the machine shop and not have to wait for parts after the work's done.
Still got the rocker gear if you want a deal. ;)
Stu wrote: Sun Oct 12, 25 11:17 am Still got the rocker gear if you want a deal. ;)
i do but need some cash in first, lol. i'll let you know mate, thanks. :thumbright:
i just ordered a cheapy clickety clack fuel pump and inline filter to convert my parts washer to use 'real' fluid that'll dissolve oil/carbon/grease etc. unlike the water based cr4p they say to use which is as much use as a chocolate fireguard stuff like paraffin, petrol etc actually cleans parts. hoo da thunk it, lol. it'll mean the parts washer will be 12v now but on the plus side it'll be more 'portable', lol.
and deal done. you knew i'd get there eventually mate. :thumbright:
thanks again, neil.
we're sort of back to plan A for engine choice, at least since i committed to the gasser build. ash' and me now have 3 352 fe's and a 360 along with 390 crank', rods and pistons which'll go into 1 of the 352 blocks for future 390 build. for now though the nash will be getting the 360 and a tremec t5 manual box. like with the 4r70w o/d auto the t5 manual has o/d so will work well with the 3.73 exploder axle gears.
i'm collecting an ally 10 gallon fuel tank for the nash next weekend (thanks Gary) so that'll save me pulling the dent and welding the split on the bottom of the stock tank where it was drained with an axe :roll:
some bits arrived for my nash today.... a chucas 70a alternator, a chucas gold coil and a chertronix electronic ignition conversion to fit the new points dizzy i have for the fe engine here.
i just had an email from jay brown in the states. he runs the 'fe power forums' and builds, races and makes parts for fe ford engines. he's had a new batch of his intake manifold adapters made and asked for my address to give me a shipping price. they allow the use of any 351c 4v inlet manifold which as you can imagine are more plentiful than fe ford ones. especially as i intend to fit a tunnel ram to the fe i'm putting in the nash. tunnel ram's are hike hens teeth for an fe so you have explore other alternatives.
