I emailed Strange and got a reply yesterday.
The good news is that they were very helpful and easy to deal with.
The bad news is the struts ain't Strange :roll:
Back to the d.i.y. solution then...
I've just rebuilt one strut and refitted it to the car, it all went back together easily. Terry is coming Monday to measure up the rods.
Cracked it! They're Art Morrison 'Superstruts' :D
https://www.artmorrison.com/frontclip-strutrace.php
Brilliant wow there not cheap :thumbright:
No, but still a lot cheaper than Strange!
At least I should be able to get spares now :thumbright:
It's also nice to know they're designed for heavy cars, and that I can upgrade the calipers easily for just a couple of hundred $$$
Digital temp gauge (actually the fan control unit) and £1.86 voltmeter fitted
Temp & volt gauges.jpg (209.2 KiB) Viewed 1997 times
fan control unit ??? Tell more link don't be shy
Another cheap and brilliant Dave999 solution Will :thumbright:
Info here...
http://www.moparuk.com/forums/viewtopic ... controller
Dave's link to the ebay item is long dead, this one's the same though...
http://www.ebay.co.uk/itm/10A-12V-Digit ... 1e863d9409
Scroll down this page to see how I fitted the sensor...
http://www.moparuk.com/forums/viewtopic ... &start=255
12 volt version of a central heating or greenhouse heater control :)
pay no more than £ 15 all in
unscrupulous peeps flog em as auotmotive fan controlers at £150-200....
naughty naughty very naughty
can't take credit for the volt meter....think that was morgan.... :)
expect Chinglish instructions or indeed nothing but fag packet diagram on ebay link.
has internal relay switching but i'd use to control proper automotive relay to switch on yer fan. they pull 40 amps plus on startup
The AM struts are based on U.S. Datsun 810 series cars, they use the same shocks as the 280ZX, amongst others.
There's a great parts search tool on on nissan4u.com with exploded diagrams and part numbers. There's a replaceable cartridge and by cross referencing the part numbers I found a KYB item available from Rockauto.
So, full of excitement I ordered them from Rockauto.
Within 5 minutes of this, I found them on Jegs. Good news- they're almost double the price of Rockauto.
Bad news- they show the dimensions. At 16" compressed they're a good 4" too long :?
Dammit. Order cancelled. Back to plan A. Oh, hang on, I didn't have a plan A :evil:
KYB 365013 shock insert- close but no cigar....PNG (139.66 KiB) Viewed 1873 times
New oxygen sensor fitted today. We have afr readings again :D
Only stung me 50 quid :?
GJUK
Post by GJUK »
Your car look badass, love it. Looking great.
I've had an enquiry about my exhaust routing so I thought I'd put a pic up here...
Belve from below.jpg (198.94 KiB) Viewed 1772 times
Scooby
Post by Scooby »
Cheers mate nice shot..
072
I had a great trip out in the car last weekend, about 180 mile round-trip to a car show near Shrewsbury.
I got a last minute invite on Saturday evening , at which point the car was on stands minus the sump, I also needed to check the valve clearances :shock:
I got it mostly done, but was up early pouring the oil back in at 6.30am!
The car ran pretty faultless, the weather was great and the show was good, a lot of variety :thumbright:
Great news- the motor is oil-tight at last.. no a single drip!! :D
My only issue- sometimes when I stop and let it drop to idle, it'll stall or idle low and the AFR goes high, like 18-20. Any thoughts?
Paul, my idle goes high at idle. I can alter pretty easily just using the 4 idle screws. AF changes are pretty immediate. Did you set idle with vag guage or AF guage?
When me and the noys were tuning my car at Shakey the best vag gauge reading did not equate to best/leanest AF ratio.
