Crankscraper
I went dry sump once.
But then i welded a patch over the hole in the sump and it ran much better. :thumbright:
AllKiller
Post by AllKiller »
Painting the block ( inside) :D speeds the oil return to the sump, but i would guess its not so important with a scraper.
How many times have you let of the loud pedal at the top of the strip and the oil light flickered on or the pro light came on for a second ? :shock:
that will be less likely due to the scraper too.
But the reduction in rotating mass will be the HP winner
ALL KILLER NO FILLER
Ivor wrote: At this rate it won't be long before we all convince ourselves to go dry sump!
scraper would still be good ... cuts the oil out of the whirlwind and gets it back to the tank quicker
:D
so is there any downside to fitting a scrapper for a street car? benefits seem good for the money.......
AllKiller
Post by AllKiller »
Hi mate, you never used to be on the skyline website did you only there was a mark n lindsey on there ?
depends how you dive and what you expect..its free HP and oil control at the end of the day not a bad thing
[quote="Perhaps Cometic could make a combined scraper and gasket, has to be a market for it.[/quote]
I took a look at the crank scrapers late last night, Cometic could cut one no doubt about it but as far as I see it there are a couple of problems as far as combined gasket also.
Cometics AFM is aluminium with a blown foam coating on both sides, this I don't think would be strong enough, it's great when sandwiched between 2 faces but there's a lot of the scraper that isn't.
Another problem is the AFM is coated in sheets then cut so the whole lot would be coated, this wouldn't allow oil to run very well.
Also while the cometic AFMs are reuseable, I wouldn't without a smear of "right stuff" just to be sure, so first time dry, 2nd sealed, 3rd bin it, not many people would want to bin the scraper and buy a new one after a few removals.
Here's what I think...... if the Cometic gasket was made wider in the areas where the scraper would be then a seperate scraper could be bolted (and loctited) to the gasket, the scraper could be cut out of stainless so it would be stronger but no where near as heavy as that steel one, customer has the scraper for life and simply replaces the gasket as needed, no sealer like the steel one would need either.
Come to think of it the whole gasket could be a little wider and incorperate a bolt in mesh screen also..... HHHMMMMM.... who thinks what???
also, i've fitted a few Chenoworth girdles, doing it this way would mean the oil pan retaining nuts are as close to the block face as possible, it would only be a small amount but worthwhile maybe
AllKiller
Post by AllKiller »
Sounds like a plan Neil :thumbright:
never owned a skyline and wouldn't want to either................
MrNorm
Post by MrNorm »
Sound idea, I got mine from Kevin at Ishihara-Johnson (crank-scrapers.com), super nice guy and was happy to answer my questions
AllKiller
Post by AllKiller »
Gav thats him, im getting one thanks to Blue pointing me in the right direction...gotta be worth the small price.....oil pan studs gotta help too when fitting all this.
AllKiller
Post by AllKiller »
marknlindsey wrote:never owned a skyline and wouldn't want to either................
OOOO get you, :P
your loss son, if you aint driven one you have no idea just how good they are..
..anyway where were we
MrNorm
Post by MrNorm »
AllKiller wrote:Gav thats him, im getting one thanks to Blue pointing me in the right direction...gotta be worth the small price.....oil pan studs gotta help too when fitting all this.
Yup, I think they pretty much wrote the book on aftermaket scrapers, they know their stuff and are pretty cheap to boot!
Worth thinking about dowelling them to the oil pan rail too, funnily enough Blue and I were chatting about this just yesterday.
AllKiller
Post by AllKiller »
Yeah with you there Gav, dont want that moving about :shock: :shock:
thank to Mick I now have cleavit cam bearings to fit to the block I have here.
Once these are in i'm going to mock a crank scraper, mesh screen and windage tray all in one in ally
i've asked Cometic to do me an oil pan gasket 2 1/2" wider than stock, all on the inside,
mi brothers a fabricator/tig welder so we'll see
AllKiller
Post by AllKiller »
Stroker crank Neil ?? 4.15
