Steering through sump
Would the Unisteer bolt on rack give you more clearance, and getting a RHD rack, non power steer.
http://www.unisteer.com/mm5/merchant.mv ... e=MOPAR+BE
ALL KILLER NO FILLER
I don't like the look of that system at all, rack hanging in the breeze on those long brackets, and what sort of crazy angles would the UJ's be at to hook up the column? And as Dave say's, it could well have bump steer issues like a lot of these conversions do.
- Cannonball
by the look off that, that system would not help kev in the sump department anyway, looks like it is designed for the regular centre bulge sump,
http://www.pentastarparts.com.au/sunsho ... ail&p=1699
use one of these and go through the sump.
this is a welded setup rather than bolt on bits hencve shouldn't flex and keeps the rack at correct hight to avoid bump steer
or use one of these and have very bad bump steer
http://store2.hemiperformance.com.au/in ... &catId=193
weld in the cradle lower
I fiitted the deep sump with the tube through on my Dart , what a pain in the ass, first problem i had, was the link was catching the sump because i'd fitted the motor on elephant ears and was in a slightly different position to stock, then it wouldn't hold prime because of the large lines, remote filter and constant minor leaks. In the end, i drilled the block, fitted a 1/2" internal pickup and conventional deep sump.
This was all before the internet , so it was all trial and error.
