collapsed lower joint?
the dodge
Post by the dodge »
cheers
that part probably originated in mexico
I have seen ball joints "repaired" to get them through an MOT before. Cut open, packed, and tack welded together again. Just tack welded to save from melting the plastic bit. Obviously these can come apart in time.
If that lower ball joint passed through an MOT any wear in it would have been picked up easily during the test. So there is a chance it was bodged at some point to get through.
Or it could be just a faulty part as already said.
Never seen one pull apart like that before, must surely be a defective part? Only other thing I can think of, if the torsion bars were cranked up high, so that the upper A arm could be hitting it's bump stop, that would be trying to pull the lower joint apart....
Guy wrote;
Didn't Neil have something simular happen to him on the way down to the Nats this year?
blimey :shock: that`s a bit spooky, remember you were parked up next to me at the Nats when my upper ball joint had popped out of the UCA.
Glad to hear everythings ok with the bodywork, could of been nasty!!
steveo
Post by steveo »
:shock: blimey neil you was lucky also !! what did the upper control arm threads look like ??? did it just pull the threads
both lucky no body damage I’d say
remind me never to park up between you 2 :D
wow
Wow scary :shock:
Common wear and tear fault on older unserviced Mopars, this paticular problem.
The lower balljoint is always under load from the torsoin bar, so hard to check for wear???
As previously mentioned, IT HAPPENED TO ME ALSO!!!
Would recommend always changing these if they look old and unchanged in recent years!!!
Bozobacca. once bitten twice shy!!!
