Hoosier Quike times, street. inner tubes????????
BUDGIE
Post by BUDGIE »
Wouldn't recommend using a tube in a low profile (50 series profile) tyre [-X
umm whys that then budge???
will it just balloon the tyre due the the difference in height to width???
Do they run hotter? Come on Birdy, spill the beans! :?
lol, well i spoke to alan (they were on his charger), and he said no tube too, so thats what they got, see pics in my car progress section.
cheers lads (and pete)
Guy
Post by Guy »
They dont make /cant make tube that shape Kev,
Points to note are
If using a tube type tyre on the street without an inner tube fitted and you were involved in an accident the chances are your insurance
would be void
The bead on a tubeless tyre is designed to lock into the rim where as a tubeless rim and tyre where not designed to lock together to allow easier removal.
It is ok to use a tubeless rim with a tube type tyre with correct tube fitted but not ok to use a tube type rim with a tubeless tyre.
NaughtyAlan
Post by NaughtyAlan »
Should i run tubes with my TOYOS, as they lose pressure so quick i have to keep pumping them up in the pit lanes :help:
big block
Post by big block »
Are hoosier quick times any good ? I am thinking of replacing my mt drag radials that have been great but unavailable at the moment,plus they look a lot more road legal. any comments please ?
big block
Post by big block »
So nobody uses hoosiers then ? :read2:
They are very good, and I use inner tubes with them.
I have a set of 325 x 50 x 15's and they have been great.
However, the car must run on slicks now so I will be outing them at the beginning of the season...
big block
Post by big block »
Thats the size I was looking at pete, what size rims are you using them on?
I have got them on 8 1/2"s, but they need to be on 10" rims really....They are purely "get to the track" tyres now.
big block
Post by big block »
would they fill a 10 inch rim and are they as sticky as MT street radials
by the way are they actually cross plies (bias belted)?
big block wrote:would they fill a 10 inch rim - YES
and are they as sticky as MT street radials - DON'T KNOW
by the way are they actually cross plies (bias belted)? - YES
big block
Post by big block »
cheers :thumbright:
The Q/T's I had said on the sticky label Not for Highway use and an inner tube must be used.
