Aussie links for when you get stuck
Plug for me ...
www.aus-ford-uk.co.uk
More
after we lost some posts the list of links went
feel free to add anymore
Spare parts
http://www.bluestarspares.com.au/index.asp
headers starters etc
http://www.castleauto.com.au
Rack and pinion conversions hard to get parts pattern parts
http://www.elkoperformance.com.au/store ... _index.asp
Borg warner Diff parts
http://www.gjdiffs.com.au/gears.asp
Spares and fiberglass panels
http://gprs.fotopic.net/c719487.html
Spares but i have had trouble with this lot
http://www.hemiperformance.com
cams (supllier of US made billets to all AU cam grinders also import Crane stuff lifters retainers locks and springs and rebox
http://www.crowcams.com.au
Holders of the blueprints for borg warner Aus gear. re seller of spiceraxle (BW)
http://www.motospecs.com.au
Flywheels and clutches
http://www.npcperformance.com.au
Widest range of valiant spares on-line
http://www.pentastarparts.com.au
Rubbers
http://www.scottsoldautorubber.com.au
engine parts
http://www.stmarysengines.com.au
Custom cams
http://www.surecam.com.au
cams
http://www.tighecams.com.au
spares
http://www.valiantparts.com.au
Cams
http://www.wadecams.com
Headers
http://pacemaker.com.au/faq.html
race parts ally rockers and superchargers
http://www.yellaterra.com.au/
Big brakes
http://www.hoppers.com.au/
Suspension speak to Roger on this board he imports this stuff for modern holdens
http://www.pedders.com.au/
Manifolds and all sorts
http://www.redlineauto.com.au/
custom alluminium bits for all aussie and US 6 and 8 cylinder valve covers side plates Turbo and supercharger manifolds as well
http://www.aussiespeed.com/
importers and resellers of Loads of stuff supply the main mopar dealers import JayCee pistons etc
http://www.precisionintl.com/html/introduction.html
balancers
http://www.precisionparts.com.au/index.html
Smashing ballancers and rollmaster timing sets
http://www.romac.com.au/
cams
http://www.waggottcams.com.au/
cams
http://www.camtechcams.com.au/
engines
http://www.site.dominatorengines.com/
any engine/gearbox combo any car
http://www.dellowconversions.com.au/
manifolds and linkages
http://www.lynxcorp.com.au/main.php?idx=home
Dr hemi's list of race parts buinesses
http://webspace.webring.com/people/jd/d ... parts.html
Message boards
sales parts classifieds and forum
http://www.moparmarket.com/
chit chat and repository for orginal blueprints + production data
http://www.hemi6pack.com/
General links
fixture fittings clevises eyes balljoints (small)
http://www.industrialgassprings.com/uk/ ... ttings.asp
http://www.illstonandrobson.com/
bearings and single loose ball bearings
http://simplybearings.co.uk/shop/index.php?cPath=23
fuel pump ID and repair
http://www.maritimedragracing.com/antiq ... cellar.htm
How does an MSD 6AL work and how to fix it....... Simples
http://holdenpaedia.oldholden.com/MSD_6AL
MSD pills how to make/change them for about 15 pence
http://www.sgizone.net/snoitcua/MSD-pill_rework.pdf
Balljoint boots without the balljoints
http://www.balljointboots.co.uk/
http://www.amsteer.co.uk/index.php?cPath=26_47
pistons from MAHLE
work out which of the pistons in their range covering all things that use pistons like compressors
will fit
http://www.motorenteile.mahle.com/eLIZA ... e/byParams
Trigger wheels for ECU EFI and DIS applications
http://trigger-wheels.com/store/
Programmable distributorless ignition
http://www.autosportlabs.com/
chemicals to make home brew fuel additive and rust removers
http://www.honil.com/index.htm
painless wiring?
or use this mob bit more pain less cash
http://members.dcsi.net.au/ultimate/
copper gaskets
http://www.ferriday.co.uk/bits/news.shtml
British made Valves
http://www.gsvalves.co.uk/
Wet liners for knakered bores
http://westwoodcylinderliners.co.uk/ind ... ucts/size/
