Rear Light Lenses
Tim P
I intend these to be a permanent fixture providing the quality of the end result is good enough. I think the finished plastic should be pretty tough (it has little flex in it so it should resist stone chips and small impacts) and the rear lights on a 70 B body are fairly well protected anyway. I used a high optical quality resin (probably not needed) which is very stable so I think they should last ok.
Thanks for the kind words - it's been a slow process but I'm learning a lot along the way. There's been more discussion lately (see this months Classic American) around red rear indicator lenses and it may all become unnecessary but the trend at the moment seems to be the other way.
- Rogue Trooper
Good skills
I must admit I am not fond of amber lenses on old US cars, just does not look right, I plan to keep the original look.
Having said that, if you are going to convert, then what you are doing will look pretty 'factory' and very professional, unlike some of the 'bolt on' attempts we've all seen!!!
Nice one!
Nice one!
Tim P
Tim P
I got so far with the lenses and then I had difficulty finding a genuinely transparent red pigment - they were all translucent and it didn't look right. All along I have been trying to get a 'factory look' to the lenses as if they were made as a two colour lens.
Then Rogue Trouper asked me to help with his 34 Coupe (see the workshop) and the search started again. I found a really good transparent pigment this time and I now have the materials I need to get this right.
As it happens I got the Satellite lens mould out this weekend and cleaned it off ready for for another go. I hope to have a two colour prototype completed by the end of the month or thereabouts. Unfortunately the Satellite has handed rear lights so I will have to repeat the moulding for the left hand as well.
Here are some details and photgraphs of the process i used on the 34 Coupe lenses.
The mould case is a old CD multi-pack box.
The resin I got from here:
http://www.resin-supplies.co.uk/resins.htm
I used the Clear rigid epoxy casting resin. It has good optical properties, doesn't shrink or go off in sunlight and best of all it is odourless so you can cast it in the house (where it is warmer) rather than the garage.
I also used J-Wax (releasing agent) from them and also the rubber moulding compound RTV SILICONE RUBBER which is excellent, if a little pricey. Very strong, quick to cure and captures really small detail
The dye I used for red is this:
http://www.ema-models.co.uk/products/04 ... t-red.html
Which is very good. They have orange too but I haven't tried it yet. I am going to order some on Monday.
All these require use of rubber gloves (the dye is particularly toxic) and lots of measuring pots (also from ABL Stephens - quite cheap) and a weighing scales for mixing.
Hope this helps. Here are some pics of the mould, the jig and the finished results (original top right, pre-STOP paint copy top left, failed prototype bottom.)
If you need any more info let me know. I'll post some more pics as I go along
- Lens-latest.JPG (112.83 KiB) Viewed 1112 times
- P1020584 (Large).JPG (112.51 KiB) Viewed 1112 times
- Lens_Mould2.JPG (111.33 KiB) Viewed 1112 times
- Rogue Trooper
Tim, its the small black ones at the bottom in the bumper
held in by 2 screws quite plain and straight forward shape
second picture shows how i would like them
cheers Steve
cheers Steve
- Copy of mine3.jpg (109.21 KiB) Viewed 1005 times
- Copy of DSC01352.jpg (96.45 KiB) Viewed 1005 times
ALL KILLER NO FILLER
Tim P
