Heater unit removal, water pipe bypass?
Hey , i'm just pointing out the fact how the cooling system works , why plug the heater hose lines when you can use the bypass , some may not suffer any problems as the stat will open when it detects heat from the block , does'nt have to be immersed in water to operate , why let the block suffer with local overheating? a sure way to speed up limescale deposits , cast iron blocks don't suffer to well regards stratification , this is what happens when a bypass is'nt fitted , but i bet that block won't fair as well as a block that's had the cooling system operating correctly.
If the heater hoses are blanked off remove stat or use a restrictor , period.
Ever see a race motor using a stat?
Rich, just overhaul the heater and stick it back in. :roll: :lol:
You'll be glad you did in the long run. :thumbright:
You don't wanna know how many cast iron heat exchanger sections i've had to replace over the years , all due to no bypass or the bypass has been isolated.........without water 'circulating' through the block a few cylinders can overheat more than others , a constant flow of water running through the block will limit any hot spots.
Food for thought.
andyrob
Post by andyrob »
brutal my be correct, big red is plugged & now it sitting there with a cracked block, coinsidence maybe ? broken yes
life is not a spectator sport
www.andyrobinson.eu
andy robinson
68 572 coronet RT
72 440 chrysler new yorker
69 518 daytona
It is indeed food for thought. :?
Cheers for all this guys, much appreciated.
I am just going to bypass it for now and then maybe some time in the future I will buy a new heater core and reinstall it (cheers Clivey)
If it was a road car, I would certainly obtain a core and re-install.
JohnR
Post by JohnR »
Must be a rad repair place near you they can re core it and you can put it back in
John Rutledge
I'll investigate. Any ideas Dave?
There used to be a cheap radiator re-core service in a lane (Back - Goldspink lane?) off Sandyford Road.
Brutus wrote:You don't wanna know how many cast iron heat exchanger sections i've had to replace over the years , all due to no bypass or the bypass has been isolated.........without water 'circulating' through the block a few cylinders can overheat more than others , a constant flow of water running through the block will limit any hot spots.
Food for thought. :thumbright:
Sounds like a bulk purchase of the NPT fittings for the pump housing!
Can you get these Brutal; are they "standard plumbing fare"???
Yeah Some sort of braided hose or hard line job might look the best.
If someone came up with a neat little kit to suit both types of big block water pump housing they could do a little business. :thumbright:
Nahhh! They will probably end up being 1/2" copper with compression fittings ;)
Pete wrote:Nahhh! They will probably end up being 1/2" copper with compression fittings ;)
:lol:
Dave wrote:......to suit both types of big block water pump housing they could do a little business. :thumbright:
Apart from the "exit" side difference, i thought there was only one basic type. The Top is surely the same :scratch:
