Jack under gear box then undo the 4 bolts holding the cross member thing then you can get to the mount.
easy job no need to take prop off
There are 2 different types of mount a square rubber one or a round bolt type.
I have a new round one in box if need as i brought the wrong one
pm if needed
Recommendations? - prop balance and rad recore (SE area)
- autofetish
- Johnny Dart
Sorry for the delayed reply - called away on family business...
Took the prop out today. The UJs seem smooth but when I took the caps off of the rear UJ one bearing has a roller missing
which doesn't seem too good.
I'll need to remove one side of the exhaust to get the transmission mount off but I moved the mounting bracket down and the rubber mount looks ok.
Next steps - Get prop checked as its already out. Get new UJ.
