It SNOWED when I was there one year.
Bad Luck for Mopar Racers at Easter Meet
Les Szabo
A lot of the pro classes were Bananarama! off, running order was changing constantly, and Q4 on Saturday we were in the pairing lanes ready to go, so the moved us over to run 2 jet cars, Tommy had a 5.9 tune in his car, had to change that quickly, just so he could get down the track, Andy Robinson had got the suspension sorted, and we hoping for a 6.2, but Pro Mods don't like running on a diesel track, so no pro mods made a full pass, Andy had a 1.00 sec 60ft but then turned hard at 100ft and chutes came out, Sunday was No better we were called about an hour late sat in the pairing lanes until it started raining then took car back to the pits and waited and waited until it was called at around 4 o'clock.
Hell Yeah!! I'm a Redneck
Les Szabo
Yep, they certainly went OTT with them Jet cars, guess its more crowd pleasing again!......no wonder I didn't see much of PM. And yes, I hope Andy gets the rear sorted, thats an awful lot of power he has and I'm sure he will dip well in the 5's once all sorted, has run a 6.01 I believe, gotta have a track there, don't know why they don't run PM after TF and FC, surely there's 1 person who would realise thats whats needed for them to perform, not have them run after the oilers, sadly its still amateur hour from the POD......one noteable run from a PM was Friday from a foreign guy with a 6.06 skirting the wall in the Alamo lane!!
Les
Les
Re: Bad Luck for Mopar Racers at Easter Meet
Someone was being optimistic, crank, rods and pistons are all scrapLes Szabo wrote:
Went over to see Turnip, and the Cuda was broken.....right hand head was off, no piston in one of the bores, but was told, not catastrophic, crank grind etc. and all would be put back together hopefully.
Les
The C & S Dart is Chevy powered
That's crap news.Turnip wrote:Someone was being optimistic, crank, rods and pistons are all scrapLes Szabo wrote:
Les![]()
Any idea of cause ??
Ouch !!!!Turnip wrote:Spun a bearing but we didn't catch it before it spread its self through the motor
Is that you out for the season then ?
Hope you can get it sorted. Would help if I could ! Unfortunately the only use I would be is tea boy !!!( I do make a good cuppa though !)
Hope you get back out soon
I went to York raceway Saturday night,set off at 8pm,35 minutes later,sat on a roundabout with a broken U/J on the motorhome,with trailer & superbird.
Called my old fella,he came out,I pulled off propshaft,left the wife in motorhome whilst I returned home to try fix prop.
Didnt have a U/J,so called a mate,unbelievably,he had one.
Returned to motorhome,refit prop,on my way again,arrived at midnight
First run on Sunday,did burnout,got stopped for leaking oil,just a rocker cover gasket,so fixed it.
Second run,nice wheelie,no drama,9.49 into a head wind,called it a day.
First Qualifier on Monday,dialled 9.45,ran 9.49 still a head wind,jobs a good un.
Second Qualifier,running Good,100ft from traps,oil light comes on at 6500rpm,I kill engine straight away,roll off track
I pull dizzy out,oil pump drive as sheard off,game over,load up,get home.
Today,remove broken oil pump drive with magnet,put priming tool in pump,pump solid,remove pump and strip,find a piece of broken spira-lock in it
,remove nose cone,pull out engine,remove sump,make a list of parts required,and ordered them
No one said"Racin is easy"
