Bananarama! Vibration!!!!!
Dave's right, that angle needs looking at. If Auto fetish is offering a swap for checking, that's a nice offer, but check that pinion angle; UJs won't work properly if it's in a straight line.
challenger
Post by challenger »
lets not forget the 2 half moon circlips on the inside of the u/j caps to central the prop in the yoke :mytwocents:
keep it mopar !
sinny
Post by sinny »
Cheers boys, the angle could be an issue as Dave & others have said as the angle on both the pig & trans is less than 0.5 degrees.
Paul it's definately not the wheels, they have been balanced twice & the vibration is there without the wheels on!
Cheers for the offer Will, I'll see how I get on with adjusting the angle 1st. :thumbright:
Shaun 'Moparless' Senior
MMA Club Chairman
Must be driving you and mate.
Can't be many more avenues to search ?.......surely !
sinny
Post by sinny »
Indeed Gary! Doing my head in!
Jim, I don't know what you mean?
MMA Club Chairman
Lets hope its that prop angle then :thumbright:
sinny
Post by sinny »
Me too Paul, I've hoped it was about 12 other things so far!!!! :shock:
MMA Club Chairman
challenger
sinny wrote:Indeed Gary! Doing my head in!
depends what type of yoke you have but if like mine (7290) 2 of the needle roller caps have half moon shaped circlips to locate the u/j in the yoke, thats puts the u/j smack central in the yoke, some yokes are machined so you dont need them, if its the circlip style you can fit the u/j off centre if the clips aint there, had a charger in some years ago with that very prob
keep it mopar !
Jerry Smith
Post by Jerry Smith »
I'm pretty sure the prop is balanced Shaun, although it's been a while, the prop was used and will have run into the 10's and there was no vibration, might be worth having it checked though
If things get REALLY desperate I think I have a BB rebuilt A727 knocking around that you could try..........it seems to be pointing that way if you have ruled everything else out........
sinny
Post by sinny »
Thanks boys.
I've adjusted the angle of the pig to 2 degrees, now need to adjust the trans but that will have to wait until next weekend.
MMA Club Chairman
yes
make the circlip face its complete side into the yoke as you Bananarama! together
if you don't you can push them off and you will loose a cap, with them round the right way it self centres as the circlips fit inside the yoke saddles.
sinny
Post by sinny »
They are the circlip type & are on correctly. :thumbright:
MMA Club Chairman
GJUK
Post by GJUK »
How can the prop angle make such a huge change?
(serious question)
That's the sort of question only Dave999 could answer :shock:
