Carpet trimmers/fitters.
nice work 8-)
XP29
Post by XP29 »
Thanks. I do have a question. A friend has said to put the floor bangs back in before the 2nd coat of paint so the paint seals them in. I was going to put them in after like they did at the factory. Any suggestions on which way to go?
karlee1433
carpet
Post by karlee1433 »
Myself i would seal them in.
XP29
Post by XP29 »
Even though I'm (hopefully) not going to see under there again once the carpet is back down, I'm not happy about painting them in. I'm thinking maybe a bead of RTV silicon round each one as it goes in.
Another dilemma, is underlay. The carpet set comes with a thin Jute backing. My factory one is a lot thicker. I could have bought an upgrade called "mass backing" which was another $350 plus a bit more on the shipping. So I though to get something over here to put under, something like this? It states it is resistant to absorb moisture (not sure how much bull$ is in that statement). But a 2m X 1.5m roll which is plenty for the feet areas is under £30 delivered. Anyone any tips on this? Is this good stuff? Good enough? Or bad?
http://www.ebay.co.uk/itm/CAR-VAN-BOAT- ... KuFlWUJatw
XP29
Post by XP29 »
While looking for carpet spray adhesive there seem to be lots out there. Are they all much of a sameness? I'm not sticking the floor carpet down. This is for the side panel, sail panel, console and load area carpets. This is one I found, it's about £5 delivered from eBay.
http://www.livedale.co.uk/39-adhesives- ... 1048-.html
I put the sound insulation stuff under my carpet, its worth it for keeping the noise down. It will soak up moisture if you have leaks but not otherwise.
No need to get a cut to fit set, just a roll like you suggest of generic underlay.
karlee1433
carpet
The adhesive is the one i used .
XP29
Post by XP29 »
Update on this, I've been prepping the floors, a couple of small repairs, treatment applied and few layers of 2 pack epoxy applied.
Rear sail panels with new and old carpet for comparison.
Trunk divider panel trimmed and new hardware fitted.
Load area and rear part of consol done.
XP29
Post by XP29 »
Load area fitted in car.
Rear side panels painted (they are steel backed), trimmed and fitted.
Rear seat backs trimmed and fitted.
Next I need to fit the main floor pieces, then finish the consol and fit the rest of that. Plus the two small pieces on the back of the front seats. There's. Over twenty pieces to a gen one Charger!
Great work and a big improvement! :thumbright:
XP29
Post by XP29 »
Thanks Pete. It will look a lot nicer in there and feel less itchy! :lol:
The underlay that ones with the new carpet isn't as thick or covers as big an area as my origonal, so I bought some separate 1/2" thick underlay to double it up and make it nice and cosy in there. I've run a length each side with same cut outs as factory taken from my origonal.
This is the rear piece starting to be cut around the bits and bobs. Just git to trim the edges and put the holes in for seat bolts and seatbelt bolts. The quality of the ACC kits is good, same loop as origonal and molded correctly.
Bilko
Post by Bilko »
Nice job, it will transform the car when it's done.
A good tip is to use a hot soldering iron to make all the bolt holes in the carpet, it seals the edges as it burns through and keeps it from pulling any threads when you tighten the bolts.
XP29
Post by XP29 »
Good point! Thanks for the tip! :)
karlee1433
carpet
Good job its looking great.
XP29
Post by XP29 »
Carried on this evening, got the rest of the floor carpet trimmed, the middle bit of consol trimmed and fitted, plus seat belts bolted in.
Then rear seat bottoms back in, nice to sit in it again!
