68 Double D
What a great thread to have read.
This has just given me even more inspiration to get out and play.
Been through a horrible couple of years , with the thought of doing exactly what you are doing , as a light at the end.
Not there yet , but it will happen :thumbright:
Until then , I'll keep myself busy with a lovely pair of 34 F's :D
Demon James
Post by Demon James »
Nice one, Mossy and cheers :thumbright:
Hang in there mate and keep plugging away, bite size chunks.
68 Double D, 34 F's , what's not to like :lol:
DaveB
Post by DaveB »
:thumbright: have fun :thumbright:
DaveBishop
Post by DaveBishop »
Good write up car looks great. Its good to see all the family interested in something that dad does :thumbright:
2 x 1969 Dodge Darts
Demon James
Cheers guys, certainly having fun and yes it's great to have such an enthusiastic clan to get involved.
I've now finished the Line Lock solenoid move so it's further away from heat sources and now below the master cylinder level.
This, along with bleeding the master correctly
:oops: (which I didn't appreciate fully or do) should help hold the fronts and stop me rolling forward on the line when I bring the revs up.
....... all settled in a new home.
LINE LOCK MOVE 05 (Medium).JPG (237.75 KiB) Viewed 7413 times
........and there it was, gone.......
LINE LOCK MOVE 04 (Medium).JPG (255.5 KiB) Viewed 7413 times
New pipe routing
New pipe routing
LINE LOCK MOVE 03 (Medium).JPG (229.35 KiB) Viewed 7413 times
Old location above the reservoir
LINE LOCK MOVE 01 (Medium).JPG (227.11 KiB) Viewed 7413 times
Demon James
Not sure if this will work, I'm not fully interweblinkything compliant :lol:
If it does, this is a camera view I took with a GoPro mounted under the rear bumper filming my first attempt at a burn out in the Dart.
Fuel pumps a bit noisy as ever, untill the proper sound of the motor kicks in ;)
Just thought it was an interesting view and it would be interesting to hear anyones views :thumbright:
https://www.youtube.com/watch?v=bQjgUAH ... e=youtu.be
Demon James
My second run in October from inside the car.
Let off early, got a bit light at the top and as I hadn't made lots of passes I took it easy :lol: Still blimmin good fun though :D :D :D
https://www.youtube.com/watch?v=dPPoQk8 ... e=youtu.be
SJH
Post by SJH »
Great video's James, looks great fun. What times are you running ? I have a 67 Dart and you have got me thinking !
Shayne
Demon James
A 67 Dart, all I can say is DOOOOOO IT :lol: It's brilliant fun
As for times, 12.79 @ 109mph then a 12.64 @ 101 so my start improved a little :lol:
Still lots to learn and practice, roll on warmer weather :thumbright:
Great video,cool Car,looks addictive ..
Demon James
So I have now replaced the leaky master cylinder with a Strange unit from Hauser Racing, jolly decent chaps :thumbright:
I decided to fabricate my own adaptor plate and adjustable push rod to screw onto the push rod that comes with the cylinder.
I now have a much firmer feel and the pedal no longer sinks after a few seconds :thumbright:
The heat shield might need an update though as this unit is longer than the old one.
Master Cylinder adapter plate (6) (Medium).JPG (196.87 KiB) Viewed 6997 times
Master Cylinder adapter plate (5) (Medium).JPG (210.05 KiB) Viewed 6997 times
Master Cylinder adapter plate (3) (Medium).JPG (233.38 KiB) Viewed 6997 times
Making use of an old ally motor plate off cut.
Master Cylinder adapter plate (2) (Medium).JPG (206.98 KiB) Viewed 6997 times
Demon James
Finished plate and the push rod to pedal connector :)
Adjustable push rod (5) (Medium).JPG (218.17 KiB) Viewed 6990 times
Master Cylinder adapter plate (1) (Medium).JPG (227.29 KiB) Viewed 6990 times
Master Cylinder adapter plate (7) (Medium) (Small).JPG (62.29 KiB) Viewed 6990 times
Master Cylinder adapter plate (8) (Medium).JPG (216.83 KiB) Viewed 6990 times
Demon James
Last ones as its beer O'Clock :D
Adjustable push rod (7) (Small).JPG (169.48 KiB) Viewed 6986 times
Adjustable push rod (5) (Medium).JPG (218.17 KiB) Viewed 6986 times
Adjustable push rod (1) (Small).JPG (167.76 KiB) Viewed 6986 times
Nifty, I did something very similar on the Valiant, except I used a rose joint 'cos I'm fancy like that...
“It’s good enough for Nancy”
Demon James
:lol: that was the plan, believe it or not. But I used my last 4 up making the transmission braces to the cross member.
I wanted to get it done today so I went a bit "scrap heap challenge" style, it's ended up ok though, nice smooth action with no friction and with the money I saved I'm going to have a pint ;)
