ok
sounds like the input "Hot wire" position you have chosen is not the input hot wire.
do the same test with the input into each of the other 4 wires.
one is the correct one
think you have the input into the starter wire.
either that
or the child in china that made it put the slider in 180* out.
willing to have a crack at it if you can wait a bit
95, TW2 5RW
New ignition switch turns engine over on ACC1
