New Member
That Loop Bumper is cool,nice Car.
karlee1433
Welcome
Post by karlee1433 »
Welcome
Carl
Post by Carl »
Welcome my friend, thats nice and different I dont think ive ever seen one before.
*MMA-609*
"Built to be driven!"
Why me??? :banghead:
Getawaydriver
Post by Getawaydriver »
Thank you all for your kind comments, I will try and post some pictures of the car when I can figure out how to do it. Thanks Matt for posting some pictures for me.
My real name is Phillip Hodge, a similar name to Dodge!
Dave81 asked if the car was for sale at dealer a while ago and I think it was. I remember seeing the car on eBay last year. I bought the car 4 weeks ago from my neighbour.
I've since discovered that it's not your ordinary South African Dodge SE, it's been modified. At some point in its life the car has been fitted with a Chrysler 383cu BIG BLOCK!
It retains its 3 speed torqueflite auto box, but my neighbour believes the gearbox has been fitted with a shift-kit valve body and had some rear axle work. This may be good on a quarter mile racing strip or a getaway car but it's no good for taking my wife and kid out for a cruise. The auto box changes with clunk and won't shift into top gear unless I go over 40mph.
I'd like to fit the correct valve body at some point along with a better carburettor.
I went to the practical classics restoration show yesterday and saw a lot of nice Mopar. Some cars were for sale to. I took some photos so I might try and post them on here or send them to the club magazine editor.
Anyway bye for now, got to plan my next heist!
From what you're describing it sounds like the kick down linkage needs adjusting, that would account for the harsh late change up. Many people don't understand how important it is to have it set up correctly, it's hardly ever right in my experience, especially if there's been a carb swap.
hello
good to see you made it here
smashing car
383 in it? then its had a transmission swap as well
would have had a 904 if it was 318 or a 727 if it was 360 originally, but they're both small block bell housing sized motors and the 383 is not, its a big block so you would have to fit a big block trans as well
if they did that they may well have added a US axle as well.
the original axle will have BORG---><----WARNER logo cast into the bottom of the housing near the yoke and has a bolt on rear cover.
it would have been a 2.77:1 ratio 4 spider gear, cone LSD 7.8 inch ring gear diff
a borg warner M78
probably made in SA at the BorgWarner Later taken over by BTR, factory
many US axles didn't have a bolt on rear cover and the bolts that hold the centre in are round the front. no US axles were Borg warner branded although they had a hand in designing some of the smaller versions.
Australian 727 and 904 are the same as US 727 and 904 apart from slight delay in production changes (Australia and SA imported some parts and took longer to use them up) and occasionally different pipe cable and dipstick routing to cater for RHD.
and yours will have started out in Australia, probably as a KIT of parts
Getawaydriver
Thanks Dave999,
That's some useful information. I'll have look at the running gear to see which gearbox and rear axle is on the car. I hope it does have LSD.
The brakes should be should be sorted out this week, so I'll take the car for a proper drive.
I really hope to see this car in the metal this year, maybe at the Euronats??
Getawaydriver wrote:Thanks Dave999,
jack up the back with it in neutral
turn one wheel
if the other goes backwards its an open centre
if they both go the same way it has an LSD or sure grip in mopar talk
put 1 wheel down and try to turn the other
if you can
it has a worn out sure grip centre :)
if you can't try doing a spirited get away...... burnout both wheels spin and it steps out sideways sure grip 1 wheel peel and its worn out or its an open centre.
if its Aussie style I can assist with parts/advice on where to get new bits
the M78 is not well known outside of Australia Indonesia and SA
although in those counties any local car will have had a M series axle
from M50 up to M90
M60 M75 and M78 are the most common
morgans had them M76(M75) for about 3 years in the UK
later IRS variant used by TVR and Lotus carlton but no parts swap
Mick70RR
Post by Mick70RR »
Getawaydriver wrote: My real name is Phillip Hodge, a similar name to Dodge!
hodges dodge.jpg (59.74 KiB) Viewed 1976 times
GJUK
Post by GJUK »
8-)
Getawaydriver
Dodgey brakes!
Took the Dodge SE out for a spin on Saturday after removing the brake proportioning valve. The brakes were better, but still not right. Sometimes I had really good brakes, sometime I didn't. It felt like the front near side brake caliper was partly seized. A few times I'd step on the brake pedal and it felt hard to press with poor braking, but while on stop after braking with my foot still on the pedal, the pedal would suddenly move another inch or two and the brakes would become good again. It felt like one of the pistons in the brake caliper was getting jammed.
I'll have to see if I can get a caliper overhaul kit for both sides or get new brake calipers.
yours will have
either kelsey hayse pin slider calpers al-la VG VH valiant
or Girlock sliders like a VJ VK
the girlocks are the ones to get if you need replacments get caliper an bracket
either can be rebuilt
both fit on an application specific bracket
the VH bracket can be reconditioned with new pins and bushes
the VJ bracket is just a hunk of metal polish the sliding surfaces.
the clips that hold on the caliper on the VJ bracket are bolted down with a 1/3 rd thickness bolt head
grind a socket down flat to the socket entry to avoid rounding them off
the bolts are not available.
Bendix in Oz do the pads
Bendix dealers in the UK can in theory get the pads
ebay is often better.
find out the pad numbers from bendix site
or download the bendix brake pad app for your phone and scan you actual pad into the phone to get a list pf part numbers.
then search based on that
You will note that on ebay if the seller thinks the pads are for a valiant the price goes up by 33%
if you work on the pad and caliper numbers you will get adverts for holdens and fords and the parts cost less.
Getawaydriver
Thanks for all this information Dave999.
The kids are back in school next week, so I'll have some time to check the car over and compile a list of parts that I need.
rockinpete
Post by rockinpete »
Welcome mate, nice motor :thumbright:
