New shoes
I had a funny problem with the rear lights on the Polara which turned out to be a dodgy bulb. Because of the way the bulbs are installed, (glass bit uppermost) when the filament failed, the wire fell back into the base of the bulb & shorted itself out. Otherwise it would have just been a bulb that obviously wasn't working.
... probably completely irrelevant.
Rebel
Post by Rebel »
might be worth checking the courtesy light switches as well
'68 Dodge Charger
‘75 Ford Ranchero
'93 Toyota Hilux Surf
YouTube - Double Zero Garage
Adam
Post by Adam »
Stu Twin wrote:I had a funny problem with the rear lights on the Polara which turned out to be a dodgy bulb. Because of the way the bulbs are installed, (glass bit uppermost) when the filament failed, the wire fell back into the base of the bulb & shorted itself out. Otherwise it would have just been a bulb that obviously wasn't working.
Yes Stu, one of the brake lights had burnt a filament, but replacement didn't help.
Adam
Post by Adam »
Rebel wrote:might be worth checking the courtesy light switches as well
Thanks Nigel. Fuse blows as soon as you open either door, so I thought it unlikely that both switches would fail simultaneously. But I will unscrew them and have a look...
