Small block manual Clutch help
Re: Small block manual Clutch help
Mm will be for a 3 speed manual made by newprocess or chrysler...
the chances are low that the size and spline matches you never know...but id guess no.
chrysler did use a Borg Warner t10 for about 6 months in early 60s, no idea if the spline was the same as the T5....i don't think it was
newprocess looked at the t10 and said we can do better than that and come up with the A833
just like the 23 spline plates for Aussie chryslers and UK ford are just different enough not to work...
TIB3300
Post by TIB3300 »
Again thanks Dave. I think I will just stick to the Ford plate and dodge pressure plate :thumbright:
TIB3300
Post by TIB3300 »
Ok I need a 10.5 clutch,
Doe's anyone have a 10.5 pressure plate at home in garage, they could give me a dimension please
Am looking for the inner dimension of a 10.5 pessure plate :read2:
TIB3300
Post by TIB3300 »
I know I have posted this info in my build but just incase someone wants it ay a later date
All from rock autos
All bolted to 10.5 Dodge flywheel
Dodge MU16751G {#90314}
10-1/2" Clutch; Diaphragm Style
1999 V8 Mustang 381021 10-1/2" X 1-1/16" X 10T
you have about the same amount of meat around the cover plate bolts as i do with a 10 inch holden v8 clutch on a flywheel designed for a 9.5 inch aussie mopar clutch
its worked fine for me..although derek was heard to say how the hell do you drive that in traffic, the weight of that clutch is horrible....
you get used to it....
i have one grotesquely muscular leg, with a huge buttock at the top that i polish up with false tan
and a pale straw dangling from a dainty boiled egg on the other side
spend my life walking in circles.... :D
TIB3300 wrote: Tue Mar 31, 20 8:03 am I know I have posted this info in my build but just incase someone wants it ay a later date
All from rock autos
I assume you have now got this all sorted and installed?
Well done for your perseverance.
TIB3300
Post by TIB3300 »
Dave999 wrote: Wed Apr 15, 20 3:56 pm you have about the same amount of meat around the cover plate bolts as i do with a 10 inch holden v8 clutch on a flywheel designed for a 9.5 inch aussie mopar clutch
:lol:
TIB3300
Post by TIB3300 »
Pete wrote: Wed Apr 15, 20 8:18 pm
All from rock autos
Thanks
No!, am on with fitting the engine at the moment
I am known for my tenacity , well I think thats what you call it ? :banghead:
