1967 Barracuda Rag Top. RHD.
Re: 1967 Barracuda Rag Top. RHD.
Disc brakes, anti roll bar, torsion bars, rear axle and springs are the only parts Common with the Fomula S cars. Apart from the engine & transmission, the Formula S package also included faster ratio steering, rallye dash and higher trim level, larger radiator and viscous fan package and no doubt a few other bits I've forgotten. The thinking was European buyers would expect better handling and brakes than the average American buyer. Tony O told me the RHD cars became very expensive by the time they were sitting on Warwick Wrights forecourt, much the same as a new Aston Martin at the time.
- Trigger_Andy
Ah ok cool. Cheers.Blue wrote: Mon Jun 22, 20 5:22 pm Disc brakes, anti roll bar, torsion bars, rear axle and springs are the only parts Common with the Fomula S cars. Apart from the engine & transmission, the Formula S package also included faster ratio steering, rallye dash and higher trim level, larger radiator and viscous fan package and no doubt a few other bits I've forgotten. The thinking was European buyers would expect better handling and brakes than the average American buyer. Tony O told me the RHD cars became very expensive by the time they were sitting on Warwick Wrights forecourt, much the same as a new Aston Martin at the time.
- Trigger_Andy
Anyone registered a car that does not have the V5? All Ive got is the Vin number.
Tony O is probably aware of your car, it's possible he might know the reg no. which would save a lot of hassle.
That is the best start point then just apply for log book. Could there be old photos of it at events showing the reg number?Blue wrote: Wed Jun 24, 20 8:26 am Tony O is probably aware of your car, it's possible he might know the reg no. which would save a lot of hassle.
If none of the above work then it will be a case of writing to DVLA with the VIN number and start a process with them.
- Trigger_Andy
Cheers guys. I'll message Tony first.
you would probably get away with a VE VF VG dash case and binnacle that would get a RHD dash in that fits
barracuda dash think thats a 1968
VF valiant dash
should fit
VF valiant dash
should fit
I have a dash frame,no glove box door,it's been outside ,so I'd say the clocks are kaput,it's had holes drilled ,give me £30 ,no pad either,I sold that a long time ago,you could put some aftermarket clocks in ,,it's a start at least,sorry about pic ,it up in the roof of my garage
- IMAG2219.jpg (77.45 KiB) Viewed 4437 times
- Trigger_Andy
Ohhh nice! I may well take you up on that offer.terryr wrote: Thu Jun 25, 20 6:11 pm I have a dash frame,no glove box door,it's been outside ,so I'd say the clocks are kaput,it's had holes drilled ,give me £30 ,no pad either,I sold that a long time ago,you could put some aftermarket clocks in ,,it's a start at least,sorry about pic ,it up in the roof of my garage
Thanks again.
- Trigger_Andy
You're right! Tony has all the info on it! He knew the vin and the reg and the full fender tag info. Amazing and very helpful. Im applying for the log book today, its all printed out and filled in now.Blue wrote: Wed Jun 24, 20 8:26 am Tony O is probably aware of your car, it's possible he might know the reg no. which would save a lot of hassle.
On a FB barn finds forum there is one, maybe two Fastback Barracudas getting pulled out of a field/yard and sent for scrap.
- Trigger_Andy
Cheers Dave! Good info there, good to have some options.Dave999 wrote: Thu Jun 25, 20 2:04 pm you would probably get away with a VE VF VG dash case and binnacle that would get a RHD dash in that fits
VF valiant dash
should fit
Locating a rusty RHD car would give you the vast majority of the parts you need, and they are out there. And if said car was a fastback there Are parts that you couldn’t use but I could....,
- Trigger_Andy
I'll keep an eye out.Blue wrote: Fri Jun 26, 20 5:33 pm Locating a rusty RHD car would give you the vast majority of the parts you need, and they are out there. And if said car was a fastback there Are parts that you couldn’t use but I could....,
Managed to track down some pictures off of the internet with the help of some guys on an American site. Hopefully I can track down the previous owner and locate some of the bits if they still exist.
- ebay_151715452666_3.jpg (70.6 KiB) Viewed 4327 times
- ebay_151715452666_4.jpg (81.08 KiB) Viewed 4327 times
- ebay_151715452666_5.jpg (57.49 KiB) Viewed 4327 times
- ebay_151715452666_11.jpg (71.65 KiB) Viewed 4327 times
It's possible whoever stripped it for paint still has all the parts if you can find out who they are. I wonder if they are still assuming the body shop is still cracking on with it
- Trigger_Andy
That is a concern.Blue wrote: Mon Jul 06, 20 3:26 pm It's possible whoever stripped it for paint still has all the parts if you can find out who they are. I wonder if they are still assuming the body shop is still cracking on with it![]()
