Interior panel restoration
Matthew Saxon
Re: Interior panel restoration
Post by Matthew Saxon »
I’m just in the middle of this, it’s the original wheel, I still need to polish up and darken the milliput but it shows what you can use it for. It shows up very pale in these, but a bit of WD40 will darken it or good old fashioned black ink from an ink pen cartridge. Deciding whether to sand and buff the whole wheel rim, or leave it and keep the character.
I use Zinseer waterbased paint for lots of stuff. Its brilliant. I discovered it when researching what paint to use to repaint my UPVC front door which is black. Its absolutely brilliant stuff and I feel pretty sure it would work well on pressed plastic panels. Will dig out a link and post it up....
Thanks both.
Once I get around to it, I’ll post up some results with the spray I’ve chosen.
I used to use milliput a lot for work, when I was younger. It’s good stuff, but not going to give me the finish I’m looking for on this one. Should work pretty well for what you are using it for though, I would think.
As there isn’t any particularly deep gouging, my feeling is it would show up and filler I tried to use, particularly as the texture is quite defined and would be difficult to match unless I painted everything.
They do a slightly textured version of the spray treatment I have, might look at that if the first attempt doesn’t work.
Blue wrote: Tue Jan 28, 25 3:59 pm I used to use something similar in the ‘90’s Black plastic external trim would always turn grey after a few years, the stuff was almost like an oil you rubbed on and it did the trick. It would go grey again after a couple of months and you’d have to do it again. I’ve seen videos online of people warming up discoloured plastic panels to supposedly bring the oils in the plastic back to the surface and the original colour appears before your very eyes. I’m very sceptical that it actually works, it’s liable to be a crock.
Was it Back to Black. I sprayed some years ago with satin black, they lasted years.
Matthew Saxon
Yes I think Milliput is to bulky for fine repairs, although for a big area you could use a damp fine sponge to create a stippled surface. I’m quite pleased with how it worked out on the steering wheel, not invisible but ok. This is sanded back to P800 with a slight buff with wax.
Yes that looks very good and not noticeable, well done :thumbright:
Great job, looks spot on :thumbright:
