Good news. It could only be so much with a starter. Well done.
Ref gunk - thats not a huge build up. A few months of damp would cause that - get some heat cycles through it before getting too worried.
Fi-tech - they need to learn. And to learn they need to monitor. And to monitor they need to have some 'normal' run cycles.
You are in a bit of a vicious circle. Get the car starting , get some heat cycles, see if the gunk clears, let the fitech learn and settle. You are on the way...
These old cars have you second guessing everything - mine does it ALL the time. Ask this forum... I've had 1,000 questions that turned into nothing
The Money Pit !!
Re: The Money Pit !!
Billybob780
Cheers lads for your help and support. It'll be a couple of weeks before I can do owt else just ballsed up my big toe...
- IMG-20250605-WA0008.jpeg (55.39 KiB) Viewed 12353 times
Doh !
OK, add 'fix toe' to the list...
Billybob780
hope you didn't kick the car that hard
Billybob780
Do you what I can't remember doing anything! The podiatrist said its had a significant trauma....... not as much as I did when they hit me with a bill of £400...
