a bit of this and a bit of that
Re: a bit of this and a bit of that
that's the other side done and both back on the stub axles ready to make the caliper brackets. we fitted the pads, pins and clips so they'll sit centrally over the discs. more soon. :thumbright:
IMG_0002 - Copy (29).JPG (104.99 KiB) Viewed 762 times
IMG_0003 - Copy (25).JPG (94.18 KiB) Viewed 762 times
today we 'propped' a caliper in place, my they're a tight fit on a little viva upright! the top caliper lug is tight behind the upright itself so the bracket must be threaded. this means drilling the threads from the caliper lugs and using bigger (and countersunk) bolts/screws from the disc side into the new bracket. the caliper will have to be bolted to the bracket then the assembly slid over the disc and bolted to the upright. it's all good fun :thumbright:
IMG_0002 - Copy (30).JPG (125.13 KiB) Viewed 700 times
i forgot to mention i'd ordered a set of stainless cap head bolts for my 390 engine build. everything that bolts to the long block will be with these nice poncy bolts and yes i'm a tart 😉
back to the viva discs. the countersunk bolts/screws arrived yesterday so we countersunk the caliper's bolt holes after drilling their threads out. then we cut the caliper brackets from 10mm plate. we'd already drilled and tapped the relevant holes as it's easier to work with a 10"x4" lump of plate than fiddly smaller bits. especially as the top parts were seperate from the main section so it would tuck behind the upright. we also shaved what was a raised section of the lug on the caliper top to let the bit of bracket move an extra 30 thou ish away from the upright. the 'bit' still needed a chamfer where it was closest to the upright. it was a case of a little here and a little there to get it all together in that area. so with it all bolted in place we tacked the top bit of bracket to the main piece and removed all the supports. the disc spins nicely and as a bonus the 14" wheel fits with at least 1/4" clearance all round the caliper, a thing i was a little concerned about. at least the wheel studs are long enough that a slim spacer could be used if required. we didn't need to as it all went to plan with good clearance.
IMG_0003 - Copy (26).JPG (109.29 KiB) Viewed 642 times
today we mocked up and tacked the other caliper bracket. then both were fully welded, ground smooth and painted black. we also cleaned and painted the new discs centres and the rings cut from the old discs centres. it'll all get assembled tomorrow ready for tony to collect :thumbright:
i thought i'd better show the completed project now we've assembled it all. :thumbright:
IMG_0002 - Copy (31).JPG (132.61 KiB) Viewed 512 times
IMG_0003 - Copy (27).JPG (111.76 KiB) Viewed 512 times
for added insurance i've just ordered ARP rod bolts, mains studs and head studs for my fe 390 build 😁
​​​​​​​neil.
we got back to the wolseley today. the rear axle, springs, shocks and remainder of the exhaust are now on the floor ready to mock up the opel monza axle and new 5 link kit with coilovers. i forgot to take any pics, doh! 🙄
i had a day off yesterday as it was my birthday.... 62 years young :-$
today we unburied my transmission jack, the choice of anyone fitting gearboxes,axles, front clips etc etc on a lift. i even used it to lift the small block in my valiant from underneath to help with fitting the new headers, lol. so with the monza axle on the jack we lifted it up to the chassis' bump stops so it's roughly right front to back. then with some measurements side to side we have it about right to start mocking up 4 link bars. it looks straight away like the front leaf spring hangers will be in the way so need removing, easy enough.
more soon :thumbright:
IMG_0002 - Copy (32).JPG (113.13 KiB) Viewed 98 times
IMG_0003 - Copy (28).JPG (119.37 KiB) Viewed 98 times
