Rob & Stu's 63 Polara 500
more pics...
and finally....
Trigger_Andy
Post by Trigger_Andy »
I see the last picture is entitled 'the other half trying to find the hole(s)!'
Is he your 'special friend' Did he manage to find the hole ok?? :D :lol: :D
Yep, kinda special..... when you've shared a womb with someone you get a bit attached.... or should that be detached :D
Adam
Post by Adam »
...and I've known both of you for 20+ years and I still can't tell you apart!
Seriously Rob, the new upholstery looks sweet. Good job you don't have the superstock hood scoop, or Stu wouldn't have been able to use the hood as a table...
Trigger_Andy
Ah I see! And there was me thinking I had busted ya out of the closset :D
Quality work as ever though! :thumbright: I enjoy watching this build up, I'm like the wife catching up with her soaps! 8-)
Thanks Andy/Adam :D It is getting easier as we get older; there's many old photos from our yoof that I cant tell who's who :shock:
Should have taken a pic of all the garage, the hood is the only place available at the mo for things like sorting out the door panels - the rear seats are on the roof and the Satellite is completely covered with stuff too.
It'll be good to get it back together & start uncovering the Satellite for the 1st time in more than a year :oops:
update.......update........update........
Well, not that much progress I suppose, not to the untrained eye, at least :?
But Stu's been putting in overtime trying to get the interior finished, and doing sterling work with all the niggly little jobs like fitting the rear seats, panels, new door locks (driver's side has never worked in the 4yrs we've had it), lubricating the window mechanisms, fitting new plastic sheet/membrane on doors behind panels, window fuzzies / cats whiskers, and eventually getting the front door panels on...
...only to find they dont fit either!! :evil:
So, that's:
Instrument cluster - painted in areas that should have been plated - returned for refinishing.
Front seat covers - stitching colour incorrect. And now we've also found the front's to be too 2" too short on the seat backs - fitted, but tight.
Rear seat covers - these are too baggy!! Taken back to upholsterers to add more foam or at worst, remove stitching, trim material and restitch.
Rear panels - ok :thumbright:
New/old comparo
Front door panels - once fitted, couldnt shut the doors!! Expected them to be a bit tight with new door rubbers (windlace) and new panels, but this is because the panels are about 6mm too long at their trailing edge (opposite end to the door hinge), so need trimming :evil: :evil:
Stu's made a start, peeling back the vinyl and cutting 6mm off the card, ready to re-glue the vinyl.
Below you can just see where the panel shuts against the rubber - the panel should stop just short of the rubber....
The perils of having a car that repro parts have only been made for a year or two. It's ok for you Charger guys :roll:
This weekend we made a start on removing the old exhaust system :working:
Bolted at the 'header' end but the rest needed grinding off as some septic twonk had welded the rest of its mounting points to the hangers & the frame rails :evil:
Anyway, a couple of cutting discs later and the old system is off, with just the worts bit to come - removing the remains of whatever brackets have been cobbled together & welded to the car :roll:
Hopefully get that done next weekend [-o<
Pics to follow....
Wow, that's top work guys...almost too good to drive! :shock:
Yeah, bit bright, isnt it :shock:
Fear not, now we have rear seat belts and the kids will be allowed in the back, I'm sure it wont stay that clean for very long :roll:
You could of just gutted it and spent the money on a cage instead. :lol:
That's looking really nice,shame about the fit of some bits,it'll be spot on when you've fettled it. :thumbright:
latil wrote:You could of just gutted it and spent the money on a cage instead. :lol:
erm, I don't think I'll put it to the vote :-k
I think i know which way that would go :roll:
Just sat and read all of this, lovely car you've got there :thumbright:
Very nice, that will go really well with the Ramchargers paint job....
Good idea Blue :thumbright:
We could get some matching deck chairs to go with it too :shock:
