Rob & Stu's 63 Polara 500
Looking good Rob & Stu , don't know why you two don't like a challenge , us charger boys get this aggro all the time , now get back in that garage & Bananarama! off.
:D
bananaskin
Post by bananaskin »
Looks excellent! 8-) :thumbright:
<a href="http://s192.photobucket.com/albums/z238 ... banner.gif" target="_blank"><img src="http://i192.photobucket.com/albums/z238 ... banner.gif" border="0" alt="Photobucket"></a>
1970 Dodge Challenger 440-6
Move Over People Are Racing
James MMA/727
Looking Great! Sunglasses time 8-) 8-) (one for each twin)
That looks great 8-) , you can do mine when you've finished your own.
Adam
Post by Adam »
That interior is spectacular Rob :thumbright: The old/new comparo shows just how bright it is.
Finally got our 'restored' instrument cluster back from AutoInstruments last weekend.
This one is a spare we bought off ebay, as the speedo on the original one in the car needs attention (not the cable according to Speedy Cables). So we had them test & recalibrate all the gauges, and freshen up the lenses, needles & gauge faces.
You can just about see below that the original cluster (still in the car) has more of a chrome look to it than the one we bought as a spare, which has more painted surfaces. Shame we didnt notice this before AutoInst did the work, as they went ahead and restored it back to how they thought it would have been when new, ie new paint instead of new chrome. They said all the other 63 clusters they have done also had the same painted surfaces, but to their credit, said if we send it back, they will replate it to how we want it, f.o.c. :shock:
The last pics show the finished version with extra chrome 8-)
Just got to swap the headlamp switch over for a new one (our dimmer switch & dash lights dont work, so not taking a chance with this one).
Plus there's a bit of mazak (or whatever matl it is) bracketry missing on this spare one that's needed to mount it in the dashboard, so we'll have to make up a little bit out of sheet metal to replace it.
original cluster still in car
spare we bought off ebay, before resto
1st attempt - returned for replating
new cluster - finished article
headlamp switch to be swapped
new cluster - finished article - separated to check h'lamp switch fitting
Stu's trimmed the door panels that I previously said were too long, and fitted them, and we've started fitting the new TTI system (pics to follow), so we'll finish that before we start messing about with the dash.
Fun times :thumbright:
These are the trimmed door panels Stu got fitted at the weekend.
Vinyl peeled back, card trimmed 6mm, and vinyl re-glued. At least the doors shut now, which is nice.
As with most of these things, now the paint is starting to look more tired, with bright new panels next to it :roll:
Mind you, the door shuts have never been repainted so it is 44 1/2 yrs old :shock:
Looks great Rob/Stu , that 44 year old paint don't look bad either.
Cheers Adam, wish I'd worn as well :roll:
RobTwin wrote:Cheers Adam, wish I'd worn as well :roll:
Can't have everything Rob.
:D
bananaskin
Looking good! :thumbright:
James MMA/727
TYREMAN
Post by TYREMAN »
Splendid 8-) :thumbright:
Pics of TTI system fitted :D
After a few mins cranking, started 'her' up for the 1st time since last October, and left it running and checked for leaks. Couldn't find any so turned it off once we'd become intoxicated by the fumes :drunken: as we didnt want to burn thru the trans line that now runs right along the 3" exh pipe next to the trans pan - the only hiccup really :evil:
Rears seat in too, after going back to the upholsterers to try & smooth out some of the material that was a bit baggy :roll:
Still not perfect, but :dontknow:
Just need to sort the trans line, and re-fit the park mechanism that we (Stu actually :lol: ) fitted with a new gasket (cheers Blue!). Park now doesnt work - must be a spring or summat that didnt go back in correctly :roll:
Yeah we know it needs a wash. That rear panel under the bumper will need a bit of massaging when we get round to sorting the bodywork. Doesnt look like it, but there's 5-6mm ish of clearance above the tailpipes.
trans line needs re-routing.... or bending
Still a nasty bit in between the seat backs, but it hasnt been sat in yet so may ride up with wear [-o<
