Just wondering
hi steve whats dash 10 in laymens terms ?
life is not a spectator sport
www.andyrobinson.eu
andy robinson
68 572 coronet RT
72 440 chrysler new yorker
69 518 daytona
www.andyrobinson.eu
andy robinson
68 572 coronet RT
69 518 daytona
- mopar_mark
- mopar_mark
Plenty to read about exhausts here :pete walton wrote:Good thread ,lots of info on Blues thread.So what about headers ,i am not sure that the biggest tube is always best is there some formula??
http://victorylibrary.com/mopar/header-tech-c.htm
Some exhaust info on this link, with lots more conversion info as well: http://www.mercurypickup.com/usefulformulas.htm
after realising Ive just bought the wrong size fuel line, ive also realise that my holley blue pump @110gph is probably is bit on the wee size so was looking at holley black top 140gph
but found summits own 140gph, much cheaper, are they any good ?
http://store.summitracing.com/partdetai ... toview=sku
or even cheaper this 325 gph aeromotive, but can you have to many gph on a deadhead sysytem ? whys this one so much better value ? am i missing something ?(no cheeky comments)
advice please lads
advice please lads
www.andyrobinson.eu
andy robinson
68 572 coronet RT
69 518 daytona
www.andyrobinson.eu
andy robinson
68 572 coronet RT
69 518 daytona
- mopar_mark
The sumiit pump is just their version of a Holley pump, never heard anything bad about them.andyrob wrote:after realising Ive just bought the wrong size fuel line, ive also realise that my holley blue pump @110gph is probably is bit on the wee size so was looking at holley black top 140gph
advice please lads
The aeromotive is for EFI, hence the 45psi rating.
If you are pumping to much volume, more than required you will have dead head as you described. Also the pump is working harder unneccessarily, which can cause the pump to overheat or reduce life.
cheers mark
think I will buy the summit 140gph
they do a bargain kit with this pump but only -6 AN pipe, after what we all just said, that pipes too small to get the best out of the pump
check it out at:
check it out at:
www.andyrobinson.eu
andy robinson
68 572 coronet RT
69 518 daytona
www.andyrobinson.eu
andy robinson
68 572 coronet RT
69 518 daytona
- mopar_mark
Personally, I would not go for a kit. I prefer to order exactly what I need. The problem I find with kits is that you invariably you end up with fittings you don't need & don't have the fittings you want.andyrob wrote:cheers mark
check it out at:
