New arrival - Hey Charger
bazbiker
Post by bazbiker »
Yep if you go 727 box then you will need to get the prop-shaft or at least the yoke with it and have your prop it cut to fit
From memory i had to have 110mm cut down from the standard Aussie prop with the 727 yoke fitted when i changed over :thumbright:
1974 Chrysler Valiant VJ Charger
1970 Dodge Charger
4 speed info
http://www.slantsix.org/articles/4-spee ... speed1.htm
4 speed bits
http://www.brewersperformance.com/
4 automatic 3 speed with lockup overdrive gear its like a 727 with a top ratio of better than 1:1
JohnR is putting one in his barracuda
727 and 904 fit fine
there is a prop shaft place in feltham that will do you shaft for approx £150 if you go for the 727
basic easy fit
904 easiest as its in
727 fits but need prop shaft
Aussie Borg warner single rail from a valiant direct fit with small block bell housing
cut and shut jobs
A833 american A body or F body 4 speed with 1:1 top
needs floor cut for shift rods and maybe a kink in the shifter
4 speed torqueflites i.e ones with numbers that begin 5
need the centre of the torsion bar box section cut out and the strength put back some other way
other options
Ford Top loader
Toyota supra Turbo R154
Toyota supra W58 with steel sandwich plate
both need torsion bar box section cross meber cut
toyota w50 celica box only good for 300 BHP but it fits ok
for the toyota or ford boxes
castlemanin rod shop or dellow automtive do all the Bits
rear axle
cut down B body 8/34
might get an E body one in there
A body is shorter than standard fractionally
standard Borgwarner M78 needs beefing up if you plan to burn out regularly or drag race properly
DaveBishop
Post by DaveBishop »
PATC transmissions @ http://www.transmissioncenter.net sell all the bits for the 518 (727 four speed) swap and the forabodiesonly forum show details of how to do the swap and as Dave said JohnR is also doing this swap
2 x 1969 Dodge Darts
daward
Post by daward »
Thanks for the transmission updates
Dave - good to meet you and Matt at sunny Brooklands on Sunday. Everyone was very welcoming and we've got a lot to think about now.... :D
David Ward
'72 Valiant Charger in restoration
headlamps
Autopal (autolite india ltd) HL108 H4 is a semi sealed holgen bulb light insert with parking/sidelight
that fits
VG VH valiant
Austin Kimberly
GMH torrana
Some triumph toldedo
possibly austin allegaro
possibly ford Capri mk1 or 2
HL108 is the industry number for the sealed beams
HL108 with H4 is a bodge of the sealed beam number to indciate a combined reflector and lense with replacable bulb
that usually gets called an H4 halogen conversion insert
ideally you'd get some of these
also made by
Hella Australia until 1994
Britax australia until recently
these will fill the role perfectly
http://www.ebay.co.uk/itm/Single-Headla ... 4cfa61ec2e
or these
http://www.ebay.co.uk/itm/Hillman-Aveng ... 5ae019a071
you just need the correct buckets adjusters springs and surround
daward
Post by daward »
Have started a "workshop" thread to record progress (or otherwise..)
Cheers
David
David Ward
