Badbird
Love it 8-)
Wow. Speechless
:shock: :shock:
Mad Max on Steroids.............Looks mean as hell!
Top quality work! :thumbright:
Nice pics Rob.
Still seems weird to me, to see a Pro Mod with a shifter cable (I understand why though)
How long are those plug leads, seems a long way to the Mag, maybe the photo angle.
shovelheadrob
Post by shovelheadrob »
Mark, they are seriously long, just routed that way so that they are out of the way of anything hot or moving, whilst making it easy to service the top end.
IS THAT A 400 TRANSMISSION ??? OR AM I GOING DAFT
WOW WOW WOW
Keep the pictures coming love it =P~ =P~ =P~
Cannonball wrote:IS THAT A 400 TRANSMISSION ??? OR AM I GOING DAFT
Yep, pretty sure its a Rossler 400, seem to be a common choice of gearbox these days, Rossler in particular seem to have corned the market in the Turbo 400 or have probably the best name.
Yes, your also going daft :D :D
I WOULD LIKE TO HAVE A LITTLE PEEK INSIDE ONE MARK,,
WHAT SORT OFF DOLLARIDGE TO HANDLE THAT SORT OF POWER, ???
Cannonball wrote:I WOULD LIKE TO HAVE A LITTLE PEEK INSIDE ONE MARK,,
I'm not sure really mate, but I just spent close on $3k on full upgrade & rebuild parts for mine, so plus more for case, few other bits probably around the $6-7k
Here's a link to the site, don't think they list prices
http://www.rosslertrans.com/
pete walton
Post by pete walton »
I was watching the coverage ,The Badbird kept dragging itself over the line when in stage,,,,, check out ARs new Camaro....
shovelheadrob
We've been struggling a bit this weekend, we have a bump box for the trans brake which allows you to build boost against the T/B when in pre stage, then hit the bump button which momentarily releases the T/B for a set time (adjustable on the bump box) this "jumps" you in to full stage. It is quite violent & we chose to try a larger jump then reduce it to find the correct setting rather than starting small & increasing. We are pretty much on the mark now & hopoefully we should hit some good numbers tomorrow morning.
Andy's car is stunnimg as you would expect & he has already made a high 6 second pass.
I'll try & do a full round up of the weekend later, I've just come home tonite to have a couple of hours with the missus & my dogs who have all been missing me as I've been working away from home for the last couple of months, came home Wednesday then went racing on Thursday!
shovelheadrob wrote:We've been struggling a bit this weekend, we have a bump box for the trans brake which allows you to build boost against the T/B when in pre stage, then hit the bump button which momentarily releases the T/B for a set time (adjustable on the bump box) this "jumps" you in to full stage. It is quite violent & we chose to try a larger jump then reduce it to find the correct setting rather than starting small & increasing. We are pretty much on the mark now & hopoefully we should hit some good numbers tomorrow morning.
nice one rob is the track poor with the cold........
Rob,
I was checking out the progress on Eurodragster, good luck for tomorrow.
You have to give it to Andy, new car, 1st full pass & a 6.905 @ 217.9 MPH :shock:
