What have you still got to do before the Nats
Hemimad
Post by Hemimad »
Engine, exhaust, diff, brakes, rad, electrics.........better make a list!
I think mine is as ready as it could be, taking her to tatton park this weekend so if she gets there and back then it should be good for the NATS
Carl
Post by Carl »
Now have a sump gasket leak to sort out. Hopefully that's the lot but it is a Mopar so anything could happen
*MMA-609*
"Built to be driven!"
Why me??? :banghead:
charger01
Post by charger01 »
Get it sorted Carl. Be nice to see that car again.
scotty
Post by scotty »
find the source of that blasted rattle....... :read2:
scotty wrote:find the source of that blasted rattle....... :read2:
It's a "Feature" ;) ;)
scotty
Post by scotty »
its starting to irritate me........it cant be rocket science...... :banghead:
scotty
Post by scotty »
well, I spent yesterday afternoon under the car with a pry bar, and found the engine and trans were loose......wating for the rain to stop now so I can try it out.......maybe that was the problem....... :wav: :wav:
Carl
Post by Carl »
charger01 wrote:Get it sorted Carl. Be nice to see that car again.
Cheers Ade, its getting there dropped sump, new gasket and seals on with the help of a little EVO stick this time. Put original sump back on as the seals seemed to fit better on the seal flanges, the after market sump flanges are a good 5mm wider than stock so the seals didn't sit nicely over the flanges, only noticed when had both sumps side by side.
*MMA-609*
I need to dig out my confederate mankini ......... :D
scotty
Post by scotty »
:banghead: still rattleing.......
