Hemi into an "A" Body - How hard can it be???
Re: Hemi into an "A" Body - How hard can it be???
Fits like a glove! :thumbright:
…on a foot! :lol:
Glad to see it’s in the hole, great progress! :rr:
mygasser wrote: Sat Jan 18, 25 10:53 pm have you looked here yet on the 'for a bodies only' forum?
https://www.forabodiesonly.com/mopar/fo ... -swaps.83/
Yes, Neil; I check out all the Fora before I buy anything or pick up an angle grinder.
As with all sites, you have to be very selective about the posts and information and in the end reach your own conclusions.
sublimemike
Post by sublimemike »
You like a challenge Pete =D> =D>
It’s a very tight fit but to be honest I think the end result is actually far more practical than a 440 with aftermarket heads in an A body. That really isn’t an easy set up to work on.
Blue wrote: Mon Jan 20, 25 6:59 pm It’s a very tight fit but to be honest I think the end result is actually far more practical than a 440 with aftermarket heads in an A body. That really isn’t an easy set up to work on.
The Hemi Swap job is not for the faint hearted; and you go into this with you eyes fully open and in the knowledge that you are going to be brutal, and in this case a millimetre is actually quite a lot of clearance.
It took many hours just to get the engine in the "perfect" position in all 3 axis before it all comes together.
If the "donor" car is your pride and joy, it will cause you some pain and angst; and the conversion is probably not for you.
Having said that, I agree with Blue that IF you retain the inner Fenders, a stroked R/B engine with Raised Port Heads, big Valve Covers, and Large Tube Headers is probably more misery than the Hemi, if not to build then certainly to run and maintain.
With the Hemi, the exhausts are multi-section bolt together 2 1/4" Primaries; but you can build up the system progressively and you have to install them from underneath the car. However, they are probably easier to install than a single welded up system on an R/B Engine.
Similarly, you can get a starter motor in with relative ease, whereas on an R/B you will have the engine off the motor mounts or Motorplate and also dropping the exhaust system on the Drivers Side - nice!
Moving on, here is the next cut now that Motor is out again for the next phase of surgery...... you can see where we had to take a bite out of the Chassis rail too!! That will be boxed and plated and the forward bars of the cage will also ensure the structural strength of the car.
Pass side Inner Fender cut point.jpeg (88.27 KiB) Viewed 24381 times
Big day, and time to grow a pair and buckle up.
No magic formula, but patient trial fit, measure, cut; repeat as necessary.
.. and quite a bit of lateral thinking...
Pass Shock tower modification.jpeg (53.55 KiB) Viewed 24246 times
Pass side Inner Fender tube installed.jpeg (50.46 KiB) Viewed 24246 times
Very clever, neat solution. 8-)
I am sorely tempted to leave the opening in the Fender so there is access to the Header bolts!!!
Pete wrote: Sat Jan 25, 25 11:14 am I am sorely tempted to leave the opening in the Fender so there is access to the Header bolts!!!
Your fabricator has other plans….
I can sort of see the sense in that. :D
Stu wrote: Sat Jan 25, 25 2:08 pm
My Style Guru does not.....
:lol: Looking forward to seeing the end result.
Good to see that it’s going to *ahem* “fit”. :thumbright:
Have you got a date for the cage yet?
No, no date, but then no Tow car either........
:shock: What’s happened to the Yukon?
Stu wrote: Sat Jan 25, 25 9:37 pm :shock: What’s happened to the Yukon?
No idea, its complicated, but it does not start....
