Dan's '78 Fury (Dukes) Hazzard County Sheriff patrol car...
danny_duke01
Post by danny_duke01 »
Some rear trim,window trim & parcel shelf fitted... (16/11/2015)
1978 Plymouth Fury,4-door sedan B-body,400 cu in (6.6L) Big-Block 4 barrel V8 'High Performance'
(numbers matching with Police special handling package)
MMA / 911
danny_duke01
Rear floor painted in Hammerite rust protective paint... (20/11/2015)
MMA / 911
Good to see your still chipping away Dan :thumbright:
GJUK
Post by GJUK »
Looks great.
I can't help but keep seeing that dash and wanting to see it replaced (what with the cracks etc in it). I've no idea how hard they are to come by.
Top work, you should be proud!
sidewaysjas
Sheriffs car
Post by sidewaysjas »
Keep the updates coming, it gives us inspiration. I might even go out and start my 'General Lee' tomorrow!
Jas :thumbright:
'wouldn't change if I could'
danny_duke01
Front floor finished in Hammerite rust protective paint... (01/02/2016)
Fitting the sound deadening underlay... (14/03/2016)
MMA / 911
danny_duke01
Fitted the new dip beam switch... (1403/2016)
New CB antenna fitted and wires run under the underlay... (14/03/2016)
Another piece of interior trim fitted... (14/03/2016)
MMA / 911
Coming together nicely Danny, think this is going be a cracker :thumbright:
Looks great Danny and you really are grafting with this project. We can all see the results and its inspirational. I really must get cracking on my New Yorker now the weather is picking up. Keep it coming matey, not long till the NATS!!
Cheers Steve :thumbright:
Looking good! :thumbright:
TW71
Post by TW71 »
Brilliant dedication. :thumbright:
danny_duke01
Thanks for all the great comments guys,much appreciated!! :thumbright:
Drivers side wheel arch...38 years of dirt and crud!! (16/03/2016)
BEFORE
AFTER
Plymouth rear badge letters before and after a good clean & polish... (16/03/2016)
MMA / 911
danny_duke01
Rear Plymouth badge fitted... (17/03/2016)
MMA / 911
danny_duke01
Steering wheel removed for spraying and now trying to get to the steering wheel cowling for spraying. Indicator stalk also needs looking at as seems very 'sloppy' and does not feel right... (21/03/2016)
Indicator stalk removed and these two small pieces fell out with the unit...not sure if they are part of it or have just been slipped through a crack at some point through the years??
MMA / 911
danny_duke01
(21/03/2016)
After a clean... (22/03/2016)
Spraying... (22/03/2016)
MMA / 911
