Fifty shades of Jade
Re: Fifty shades of Jade
Fantastic work Will
, you and Blue should do a joint project, I bet it would be amazing.
- mopar_mark
Will,
What is the shielding on the Turbo exhaust , is it welded ?
- autofetish
With a Target Weight of 200kg without me on it and 800hp reliable I'm pushing for 4000Hp Per ton
Hopefully, compete in 1/2 mile and Mile events standing and flying at a competitive world level
Inconel tube heat shielded with dimpled 0.15mm stainless steel foil spot-welded and enclosing a microthermal layer to retain heat within the systemmopar_mark wrote: Sat Jul 25, 20 10:53 pm Will,
Its used in current 2019 Spec F1 Exhaust system. Pm I can put you in touch with a man that can.
Note the bead rollers that welds it on as it rolls very cool
- Capture.JPG (106.63 KiB) Viewed 3771 times
- ddddd.JPG (53.83 KiB) Viewed 3771 times
- eeeeeeeeeeeeeeeee.JPG (61.3 KiB) Viewed 3771 times
- eejejejejej.JPG (45.07 KiB) Viewed 3771 times
- ejejejeje.JPG (59.34 KiB) Viewed 3771 times
- hqdefault.jpg (34.77 KiB) Viewed 3771 times
- autofetish
Added cross bracing between top and bottom tail to strengthen the structure
- FC302FBC-FC8A-415A-93C2-AE03E65715AA.jpeg (197.94 KiB) Viewed 3751 times
- A4CD8E6E-E270-4DAF-9D7D-45A361B3AC15.jpeg (192.04 KiB) Viewed 3751 times
- 4282B11B-3B76-46A9-B4C8-AFED78C0B523.jpeg (188.96 KiB) Viewed 3751 times
- 1119192C-6343-461F-8859-9DDB3E52D619.jpeg (163.79 KiB) Viewed 3751 times
- EB1ED899-7F00-44BA-9DDD-9463D8AC6E53.jpeg (168.94 KiB) Viewed 3751 times
- 80F685C1-F870-4DD6-A34A-FF94EA18D016.jpeg (181.38 KiB) Viewed 3751 times
- B7F02240-043B-4A88-A320-23D06290A717.jpeg (150.94 KiB) Viewed 3751 times
- EFBC17E1-A0FE-4548-8FFA-3287A585F2BF.jpeg (148.21 KiB) Viewed 3751 times
- 9C233EE1-6EC1-432B-89A6-B75EF8ECEB37.jpeg (166.7 KiB) Viewed 3751 times
- C0182E21-FE03-4C94-9643-4392244E47C2.jpeg (151.22 KiB) Viewed 3751 times
- FC7EB5A8-F912-4F3B-86F7-4AE6C778A5B6.jpeg (136.73 KiB) Viewed 3751 times
- 0EACA627-FB62-4047-96F6-2FADBC73DB1C.jpeg (156.68 KiB) Viewed 3751 times
- DAC23611-4809-4FC0-A52D-97C8529034F2.jpeg (143.1 KiB) Viewed 3751 times
- C2464A9B-642C-4E47-84BD-DB8A29E100AE.jpeg (217.51 KiB) Viewed 3751 times
- 8CA7A504-805A-49C3-90FB-EFD8A4B5D457.jpeg (163.49 KiB) Viewed 3751 times
- A1913CF7-22A8-441B-ADDF-F26D1A8BCAE4.jpeg (172.97 KiB) Viewed 3751 times
- D9CA0B1D-27E8-4A43-8DAE-BB41E4C1200C.jpeg (145.4 KiB) Viewed 3751 times
- 473E4EC1-6084-431F-BFE9-4945C1245190.jpeg (163.47 KiB) Viewed 3751 times
- ACA494A4-1230-45F5-BE58-825A33B798EB.jpeg (192.21 KiB) Viewed 3751 times
- BCEEA916-21DB-44F8-8AAD-10447B938B1B.jpeg (192.44 KiB) Viewed 3751 times
- 7310FC8E-6E6F-4D6A-B481-64236263E412.jpeg (160.03 KiB) Viewed 3751 times
- C09483EC-7DA8-4297-A613-00D6955508D7.jpeg (136.15 KiB) Viewed 3751 times
- ACEFDEEB-B62F-4EEE-9BF1-7DC7E2D0DABC.jpeg (152.17 KiB) Viewed 3751 times
- B68E54F9-C4B9-40C7-B864-8E6D87C0F658.jpeg (151.02 KiB) Viewed 3751 times
- A09330E7-9542-4DF6-AB57-368F76583534.jpeg (130.24 KiB) Viewed 3751 times
- 48AA7180-835D-4EEE-B8C1-5D6F94BE49A7.jpeg (114.98 KiB) Viewed 3751 times
- B20610D0-3A6A-484D-ACD9-CED3EB20B373.jpeg (131.96 KiB) Viewed 3751 times
- 0DCDB2DE-7B38-4717-A19B-1704215E34E1.jpeg (116.95 KiB) Viewed 3751 times
- B8991F22-AE0E-458C-9CA2-401E43A3CF34.jpeg (157.24 KiB) Viewed 3751 times
- 85820AE1-F0B2-4998-B379-86942B734012.jpeg (176.73 KiB) Viewed 3751 times
- 3EC47CF9-EE0F-4948-B243-A506CFFBE1BD.jpeg (215.86 KiB) Viewed 3751 times
- mopar_mark
Thanks, will send you a messageautofetish wrote: Mon Jul 27, 20 9:52 amInconel tube heat shielded with dimpled 0.15mm stainless steel foil spot-welded and enclosing a microthermal layer to retain heat within the systemmopar_mark wrote: Sat Jul 25, 20 10:53 pm Will,
This is an epic project! I should be convincing you to put a skinny tire on the back and bring it to the salt
Coincidentally I don’t know how available and expensive inconel and other super alloy welding rod is over there, but I have a bunch of it here. Got it as a job lot when I bought a tig welder. I can’t use most of it and it’s out of tag to be used on an aircraft, but if anyone needs something odd for a project let me know and I’ll see about shipping cost (willing to bet that will be high).
- image.jpg (168.93 KiB) Viewed 3738 times
- autofetish
Thank you for the kind offer on the rod but postage will make it unaffordable.Bratfink wrote: Tue Jul 28, 20 2:43 am This is an epic project! I should be convincing you to put a skinny tire on the back and bring it to the salt![]()
Have you been to salt ? I would love a shot one day
You could say I suffer from salt fever
- 169A58E0-C437-4FC8-B9CB-B33886367D38.jpeg (114.02 KiB) Viewed 3716 times
- autofetish
I will call you
- autofetish
Next Up
Thanks to having detailed the engine all measurements could be pulled into CAD. computer-aided design.
This allowed us to design the rear engine mounting location and the Rear endplates.
We angled the rear axle plates forward 4.86° this ensures all forces and frame structure is designed about the load point towards the Engine output shaft.
Lots of holes drilled into the plates to alter rear ride height
- 55670903-0A9B-4AB3-869E-2441EA8994D6.jpeg (193.36 KiB) Viewed 3725 times
- 8EB798B0-04F4-42DB-8986-9E2140D9D48D.jpeg (195.47 KiB) Viewed 3725 times
- 6BAC8385-77DD-49CF-8629-2DAACFEF169A.jpeg (96.71 KiB) Viewed 3725 times
- 5B1E8E43-7DE0-4B39-8CCE-88DB9B3CC2BF.jpeg (186.84 KiB) Viewed 3725 times
- BA006674-CF37-406F-B859-4E3400D358ED.jpeg (129.89 KiB) Viewed 3725 times
- E9C869E7-D4CD-487A-841F-85AB87B68AC3.jpeg (180.3 KiB) Viewed 3725 times
- 0AC7E3E9-9BA7-4048-AA32-C7AA1B9180B6.jpeg (191.84 KiB) Viewed 3725 times
- EAE4AC2F-3243-4095-A01D-208F08817D55.jpeg (161.06 KiB) Viewed 3725 times
- 910C3229-3FFD-4EC0-BB53-0474D6E31D86.jpeg (183.75 KiB) Viewed 3725 times
- 963A86CE-7B0E-4C50-936C-5FBFFD6C56EB.jpeg (181.75 KiB) Viewed 3725 times
- 100AC6A1-52CE-46F9-A755-B919A9E97B1D.jpeg (162.02 KiB) Viewed 3725 times
- E9286D62-2361-4FA1-A107-854990177EF2.jpeg (184.5 KiB) Viewed 3725 times
- 683532F6-1BBF-4C3E-A0E9-AFB541E532FC.jpeg (167.68 KiB) Viewed 3725 times
- 3BBF2E7D-CDB0-41A1-B8A1-49C5F258E69A.jpeg (173.25 KiB) Viewed 3725 times
will you be laying slightly more uphill this time so you don't need to bend your neck as far as before? i'd still love to see you looking down at a screen while a dash cam/gopro looks forwards at 200mph. that'd take some balls
- autofetish
mygasser wrote: Thu Jul 30, 20 3:26 pm will you be laying slightly more uphill this time so you don't need to bend your neck as far as before? i'd still love to see you looking down at a screen while a dash cam/gopro looks forwards at 200mph. that'd take some balls![]()
We need a plan
- 6f83d149-067c-4d8a-98da-eac69054ddbb.jpg (23.1 KiB) Viewed 3696 times
- 9AFCBB37-4D49-4558-B63E-A6228050FA4A.jpeg (14.94 KiB) Viewed 3695 times
ummm. How fast will this thing go ? (serious question)
well the screen/dashcam idea is just an electric periscope. there's lots of remote vehicles run this way and it's just a matter of getting used to it i guess in the same way as you do with reversing cameras in modern cars when parking. it'd raise some eyebrows at the track for sure.
as for the speed issue drone aircraft are remotely operated with cameras and they're much faster than you'll ever go.
- autofetish
