Stroker rebuild
Bummer!!!
Any other damage???
Did you do a MattH and just drop the sump or is it Engine out and Bearing change???
Feel for you, mate...........
BB Conversion on the Horizon or are you too pee'ed off with it all?
Carl
Post by Carl »
Engine out Pete, much easier to work on standing up.
Had a check of the big ends and they seem ok, will drop a main cap and check those too. Had oil at the heads still by the looks of it but not enough pressure to show on gauge.
That's the way things go, just gotta carry on. Got expect some head aches when we come along and change everything Ma Mopar invested millions of Dollars developing.
Big block still on the cards at some point, get this one sorted first.
*MMA-609*
"Built to be driven!"
Why me??? :banghead:
Fair enough, I have a 440 in bits if you are interested, plus a re-built A727; that will sort your clutch out a treat ;)
...anyway; good luck with the re-fresh and I hope you don't find any more issues.....are you aiming to get it to the Speedfest?
Carl
Post by Carl »
Cheers Pete. No I haven't registered for Speedfest, aim to get there next year though,
Could be interested in the 440 is that the one from Duncan?
*MMA-609*
Carl wrote: ...Could be interested in the 440 is that the one from Duncan?
Yes it is, but I have another as well, as you do ;)
Mind you, it will be a bit of grief on the bell housing / clutch side of things; unless you want to see the light and go auto............ ;)
DaveB
Post by DaveB »
chances are oil pump does not sit flat on block because of aftermarket main bolts/studs.
Carl
Post by Carl »
Pump and bolts are the same that were on the engine prior to rebuild. I did check the pump was sitting flush with the block when I re-fitted it, but half the gasket had vanished when I unbolted the pump, could have been enough play to destroy the pump?
*MMA-609*
DaveB
Post by DaveB »
check again,pump will be sat on one of main bolts,the pump will be cocked over
jerry
Post by jerry »
Carl wrote:Pump and bolts are the same that were on the engine prior to rebuild. I did check the pump was sitting flush with the block when I re-fitted it, but half the gasket had vanished when I unbolted the pump, could have been enough play to destroy the pump?
DaveB wrote:check again,pump will be sat on one of main bolts,the pump will be cocked over
Listen carefully Grasshopper ;)
Edit: Jerry II
Carl
Post by Carl »
Appreciate what your saying Dave and grateful for your input. I bolted pump back up to check fitting again without touching anything else and as I said pump is not sitting on a bolt or cocked over and is flat on the block. And plenty of space between the bolt and pump body 0.035" feeler gauge slipped in nicely between bolt head and pump.
pump 2.jpg (231.43 KiB) Viewed 1583 times
pump 1.jpg (246.99 KiB) Viewed 1583 times
*MMA-609*
Carl
Post by Carl »
And plenty of room over the bolt too
*MMA-609*
Carl
Post by Carl »
Edit: Jerry II
Thanks for that :roll:
*MMA-609*
stuck relief piston? was it shimmed?
or just a minute crack in the pump that failed?
Carl
Post by Carl »
Was the pump shaft that cracked and failed and the outside casing had a chunk out of it, not sure if that missing chunk on the outer case had anything to do with it, could of caused play in the pumps shaft im suspecting. Didn't find the missing chunk in the oil or sump either, maybe missing when I installed the pump and I never noticed?
*MMA-609*
