Blue's winter refit
dustymopar
Post by dustymopar »
T'is all lookin mighty fine 8-)
Will run your steering alingment gadget back to you soon :thumbright:
Enough is never ever enough....
AllKiller
Post by AllKiller »
Thought you would have made that top rad support removeable Blue ?
Wheres the best place to get the Billet stuff, is it needed on a stroker...
or is it more belts n braces ? :shock:
Looking Good 8-)
ALL KILLER NO FILLER
It is removable, you can see the bolts if you look closely...
Blue have you had any hassle with the coloured lights? from the law?
AllKiller
Post by AllKiller »
:thumbright: Added something :thumbright:
Guy
Post by Guy »
Mo, had no interest at all from the law so far. Steve, I use John Cope for billet parts. Not strictly necessary to use billet servo's, unless using a 'brake with very high line pressure. The standard cast parts are not that stout, and I have come across broken ones, so I thought I'd use them just in case.
AllKiller
Post by AllKiller »
:thumbright: Thanks
Engine and gearbox back in at long last, still got most of the ancillaries to sort out, but it's progressing. Pictures and more details soon...
Jeff
Post by Jeff »
Wey Hey! :thumbright:
TrevD
Post by TrevD »
blue, do you have any of the billt parts in stock?? id like to measure them and maybe i could supply a similar item (but probably better ) at a reasonable cost :thumbright:
too much is never enough
Rogue Trooper
Post by Rogue Trooper »
8-) Blue did you crack open a couple,
1934 Coupe
1954 F100
1972 Norton Commando Fastback
Your Mum Says Hi.
Mopar a God amongst insects.
Philth
Post by Philth »
When's the fire-up Blue? Need a hand/extra pair of eyes? I'll be ready with the petrol soaked rag and me favourite screwdriver....
....may even bring a hammer.
And some plasters.
1973 Dodge Challenger
MMA 616
I'll let you know Phil, still have the intake plumbing and linkage to sort, numerous other small jobs too. Trev, which billet parts do you mean? Pulleys are only fitted loosely at the moment, sorry but I had to give them a coat of "Anti-bling", I can't be doing with too much shiny...
Anyway, here's where we are now.
More room in there now with a 400, ehh?
Did you sort your header clearance issues out?
