Will´s 1968 Dodge Truck
Re: Will´s 1968 Dodge Truck
Just sat and read through all of this thread...absolutely fantastic Will. Really impressive work as always. Will be interested to see how the welding around the roof goes. We did this area on a friends D100 that had rotted in the same place. Its an awkward profile and we eventually did it in three separate profiles and welded them together to make the lip etc. Not a problem with your welding skills but tested mine.
I personally think black would be nice but sure whatever you do will look ace. Difficult to find a colour that compliments the gold other than black or white in my mind but I know nothing about paint etc.
Im with Pete, PLEASE PLEASE PLEASE support us at the NEC this year...its great fun!! :thumbright:
Pumpy pumpy
Always made the mistake of building a fuel system to small and then doing it again. Not this time
Magic fuel pump that takes air out ?? Will support silly HP
prntscr
That's a thing of beauty Will!!! :thumbright:
It needs a "GREEN" rag top...... :thumbright: :thumbright: :thumbright:
Next up Electrics!
The build is pretty simple to build and truck that would withstand an electromagnetic pulse 50 kV/m+ :reindeer: EMP zombies apocalypse etc
Same as the Charger the ability to have the polish jet-wash the lot inside dash engine bay you name it the lot
Due to this 100% of all mission-critical systems will be as basic as they can with Zero transistor-based Electrical systems.
All switches and Wires will be overrated and good old-fashioned contactors used in place of relays.
The non-critical system will use tastest flashy bling bling tec but plug and play to old school like headlights etc if required
Dash Out with the old in with the new.
A joy to watch this build!
Keep the pictures coming! :thumbright: :thumbright: :thumbright:
Welded a cage to underside of dash this will hold a sheet of 20mm plastic (old lab bench top cut up)
To this sheet all electronic will be mounted
The biggest pain with the charger is working on all the electrics under the dash.
The plan with the truck is the panel will be design to come out with a long loom allowing it to be placed on the seats and worked on for upgrades.
slumbers
Post by slumbers »
Wow !! Impressive build ......Fantastic work :) :)
I'd probably use something other than cardboard for mounting electrics :D
Sorry Will ;)
Mossy68 wrote: Fri Nov 16, 18 10:21 pm I'd probably use something other than cardboard for mounting electrics :D
Sorry Will ;)
Good idea !
I cut up some very hard plastic (lab bench worktop)
Forgot how much of a mess a router makes and what a Versatile tool it is.
Drilled some square holes :reindeer:
Rubbed my golden goose on it and tested fitted everything
Looks neat :salute:
:geek:
A main aluminium beam from an old conservatory pulled from a skip !
