He does indeed use similar systems for controlling boost, all tuned by Shane T, Twin Turbo 555 BB Chevy.....Bratfink wrote: Wed Oct 07, 20 11:52 pm I think George uses a system like this to traction control Speed Demon. And he just went 481 with a single big block!
Fifty shades of Jade
- mopar_mark
Re: Fifty shades of Jade
- mopar_mark
- mopar_mark
Where are you planning to run this thing ? (serious question)
Is it now heading more in a Bonneville direction than a Santa-Pod direction ?
- autofetish
Frame all done and it’s 38kg !!RobTwin wrote: Fri Sep 25, 20 1:11 am I hope the frame is still the same weight you had planned for...![]()
Compare to a B body I’m quite happy and I think this is good ??
- 06A91D37-CEF1-4FD9-94FB-2089996E12DB.jpeg (110.2 KiB) Viewed 6742 times
- 5A861133-9F8E-46A2-9FB3-36D08F495A9C.jpeg (169.5 KiB) Viewed 6742 times
- autofetish
Next up radiator engine hoses
On a standard hayabusa these are the standard factory mess
so started making some stainless ones and will be using AN16 Braided lines braided lines for all coolant.
Just need to decide where to put the rad
- 45BB26C7-F213-424D-8259-7C6526F6060C.jpeg (154.63 KiB) Viewed 6736 times
- 81C12FA1-846D-4F3D-B2BD-4A96756B6235.jpeg (140.93 KiB) Viewed 6736 times
- 98F01E0B-9E13-41EA-88B8-5AFBF22186F4.jpeg (194.96 KiB) Viewed 6736 times
- 742AEB65-5BBA-4250-8EB1-E668A01C10B3.gif (64.16 KiB) Viewed 6736 times
- AEAB4B21-DA09-481A-A755-67866174ABCC.jpeg (114.13 KiB) Viewed 6736 times
- CD434B82-CB95-435C-89A8-2B026F0AFA50.jpeg (93.56 KiB) Viewed 6736 times
- 6CF02A5A-2309-4391-B7A0-A8F9CD5ADD36.jpeg (138.71 KiB) Viewed 6736 times
- BCBCD24F-BBA2-4DA3-8584-2AC8896A19CA.jpeg (129.32 KiB) Viewed 6736 times
- 014831A7-B505-4292-A420-FBD8B194C878.jpeg (93.89 KiB) Viewed 6736 times
- autofetish
Under-tray or some sort will need to bolt to the bottom of the chassis.
I added lots of rivet nuts to all the gussets underneath and then welded every one in so it’s 100%
Never used them before and think there quite good
- 380E57C0-C7A9-49B1-BB4B-F225201375D3.jpeg (213.27 KiB) Viewed 6732 times
- 7B58438A-792F-4BC5-92AF-E832B4641A3F.jpeg (55.7 KiB) Viewed 6732 times
- 6F87DB11-7F8D-4DEE-9066-C42339002B2A.jpeg (151.29 KiB) Viewed 6732 times
- 88CD9867-6C7B-4402-94C3-6DB4549BAD75.jpeg (138.2 KiB) Viewed 6732 times
- 36D6119D-2697-4A0E-A2CD-451B4D4C2E86.jpeg (142.91 KiB) Viewed 6732 times
- B600F17C-2277-4063-AC99-B540E7B33D99.jpeg (107.95 KiB) Viewed 6732 times
- B5389DA9-F995-4D4F-A98C-E3F94BF31572.jpeg (26.26 KiB) Viewed 6732 times
- FB956F37-553F-4888-812F-91F04245629B.jpeg (19.38 KiB) Viewed 6732 times
- 1CD4E9BD-32B5-4331-BCF5-69612E7E0123.jpeg (19.1 KiB) Viewed 6732 times
We use a lot of rivnuts at work. Seem to work well. Had no problems so far
- ScottyDave
Same hereMossy68 wrote: Thu Oct 08, 20 10:21 pm We use a lot of rivnuts at work. Seem to work well. Had no problems so far![]()
SCTA rulebook says not to fill the corners of gussets. Not sure why, but that’s what it says.
Dirt Trap / Drainage?Bratfink wrote: Fri Oct 09, 20 1:18 am SCTA rulebook says not to fill the corners of gussets. Not sure why, but that’s what it says.
Added stress in the corners?
- autofetish
There not gussets there Partial tubes very different
A great design adding maximum stiffness for minimum weight to the chassis.
- autofetish
40kg block of aluminium.
1000mm x 70mm x 500mm
Under 5kg when finished !!!
The milling machine has started !!!!
- E4E8EC5D-9C91-4FC1-B1A3-4B3E54EAED08.jpeg (157.42 KiB) Viewed 6713 times
- 563B8719-D4FC-43FA-A201-22E525642D38.jpeg (170.95 KiB) Viewed 6713 times
- 79B0AA73-DBA4-429F-85EE-92131CA90082.jpeg (209.5 KiB) Viewed 6713 times
- 480B11CE-96F7-43C2-9B12-8B065305F759.jpeg (199.56 KiB) Viewed 6713 times
- BA9ADE27-27BA-49F3-A27D-41B2389F4AEA.jpeg (169.14 KiB) Viewed 6713 times
- 783AC982-B9C1-487F-A15A-C3806A1643D2.jpeg (193.93 KiB) Viewed 6713 times
- 71B76D1E-8FF7-43F1-AA95-4470F389CE33.jpeg (238.63 KiB) Viewed 6713 times
- 2a755cd1-2f98-485d-98c9-4ac41ab31834.jpg (68.76 KiB) Viewed 6697 times
- 9ad0cb5b-7ef5-46f3-bcf5-83e8fa78d449.jpg (75.75 KiB) Viewed 6697 times
