Anton's 68 Charger - 2012 Update
Finally back on the road
Got the new steering box seal on Wednesday and fitted it Thursday night and set the ride height. Fitted new power lead from alternator to battery so the car was ready to go for wheel alignment on Saturday. Got the wheel alignment done today and what a difference. The car is rock solid and drives so much better for all the work and I'm well chuffed.All I need to do now is fit the new coolant pipe i got from Derek today and my coolant leak should be sorted.
- Wheel alignment done by Willow Motor Works in Mitcham
- 2.JPG (69.01 KiB) Viewed 3001 times
- Seal from Specialist Autoparts
- 1.JPG (67.88 KiB) Viewed 3001 times
Drivers Seat
Thanks to the generosity of Derek who gave me his old seat covers I have stripped and recovered my drivers seat with his old passenger seat cover as it was undamaged and now i have no rips in any of my seats and here are the results. I added more foam to stiffen up the seat.
- seat recovered with Dereks old cover
- 6.JPG (111.05 KiB) Viewed 2966 times
- foam was in one piece but was crumbling very badly
- 2.JPG (113.82 KiB) Viewed 2966 times
- seat base and hession in bad state
- 3.JPG (161.51 KiB) Viewed 2966 times
- Old ripped cover
- 5.JPG (137.66 KiB) Viewed 2966 times
I've only known you for a while but you know me too well alreadyANTON wrote:don't lie Derek you would have kept them hoping someone might need them some day.Remember your attic,garage and shed are full.![]()
Fitted Green Bearing Today
When i brought my car i had a bad grinding noise from the rear axle and didn't know what it was so on the advice of Derek jacked the car up one side at a time and spun each wheel and found that the noise only happened on the drivers side(i have an open diff so can spin each wheel separately).With lots of advice i brought a set of Green Bearings from DaveB(good,quick service thanks Dave). In the photos i show a step by step how the change to green bearings.
Anton
Anton
- grind at 0' and 180' through axle retaining plate and remove
- 5.JPG (68.8 KiB) Viewed 2884 times
- outer bearing race removed
- 4.JPG (44.94 KiB) Viewed 2884 times
- Grind through th outer bearing case at 0' and 180' and remove it do the same with the rollers and casing
- 3.JPG (58.6 KiB) Viewed 2884 times
- Haft shaft with original taper roller bearing
- 2.JPG (78.97 KiB) Viewed 2884 times
- Jack one side up remove wheel and unbolt the half shaft and withdraw it carefully
- 1.JPG (82.39 KiB) Viewed 2884 times
more
- now fit the green bearing and i used a scaffold pole(which is exactley the right diameter)to get the bearing square and partially started before i used the press
- 10.JPG (64.46 KiB) Viewed 2876 times
- cracked inner bearing race
- 9.JPG (58.33 KiB) Viewed 2876 times
- next grind a slot into the inner brearing race but not too deep and the again use a cheisel to crack th race and remove it
- 8.JPG (55.88 KiB) Viewed 2876 times
- cracked collar.Now it is easy to remove
- 7.JPG (52.65 KiB) Viewed 2876 times
- grind a deep slot into retaining coller(don't go too deep and damage the axle) and then use a cheisel and in the slot to crack the collar
- 6.JPG (59.56 KiB) Viewed 2876 times
More
- half shaft back in the car.The swapping of the bearings took about one hour and was alot simpler than what i thought it was going to be.there is no need to disturb the brakes when doing this job.After it was all back together i took the car for a test dri
- 13.JPG (79.71 KiB) Viewed 2874 times
- bearing press all the way home and now ready to got back on the car
- 12.JPG (70.84 KiB) Viewed 2874 times
- then it was into the press to press the new bearing on
- 11.JPG (75.5 KiB) Viewed 2874 times
Reverse light switch
As you may have seen in the wanted section I was after a reverse light switch and bracket and was told that they were very hard to get, so i decided to make one and here are my efforts.
- Side view with bolt a lever
- 10.JPG (119.59 KiB) Viewed 2803 times
- gear lever in DRIVE
- 9.JPG (98.74 KiB) Viewed 2803 times
- gear lever in REVERSE with micro switch depressed
- 8.JPG (92.75 KiB) Viewed 2803 times
- switch and bracket attached and gear lever in PARK
- 7.JPG (96.74 KiB) Viewed 2803 times
- Micro switch arm bent and wires and plug soldered on
- 6.JPG (119.51 KiB) Viewed 2803 times
