Will´s 1968 Dodge Charger
TPS
Throttle position sensor
This tells the ECU what postion the throttle is at
Now most people mount this up on engine next to butterfly's
I mounted it next to the throttle pedal under dash this ...
A. Makes it confusing when looking at engine how does it work :scratch:
B. Gives a never level of tunablity.
I will be able to make sure just before the butterfly's open fuel starts.
This will help stop the blower sneezing which can be deadly.
Made Alu house/axle block , welded rod to pedal and rose joint bar.
<a href="http://s73.photobucket.com/user/autofet ... t.jpg.html" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... iguwlt.jpg" border="0" alt=" photo 859B8BE8-D800-4A1A-BC68-7AF7DB3097EA_zpsagiguwlt.jpg"></a>
<a href="http://s73.photobucket.com/user/autofet ... u.jpg.html" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... ovbjdu.jpg" border="0" alt=" photo E05A9C00-3FE5-4773-A578-F37630C6C4D5_zpszaovbjdu.jpg"></a>
<a href="http://s73.photobucket.com/user/autofet ... p.jpg.html" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... mbfxup.jpg" border="0" alt=" photo 47DC3B81-77DA-4064-B52E-A031653D6C59_zpsedmbfxup.jpg"></a>
<a href="http://s73.photobucket.com/user/autofet ... j.jpg.html" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... qxsxxj.jpg" border="0" alt=" photo 5A407831-B3A3-4680-B2F1-DF04BF72FE3F_zpsjqqxsxxj.jpg"></a>
<a href="http://s73.photobucket.com/user/autofet ... r.jpg.html" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... mazvjr.jpg" border="0" alt=" photo 478E6228-7EB3-456B-A44F-3BDD1113A589_zpsbsmazvjr.jpg"></a>
<a href="http://s73.photobucket.com/user/autofet ... n.jpg.html" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... stip4n.jpg" border="0" alt=" photo AFD61744-B69C-44CA-A1E1-607301B420D3_zps17stip4n.jpg"></a>
Fuel tank
When I made my lowered boot floor I made it a little bigger than the tank.
So I coukd line it (from demon Tweeks its £97 a sheet) or you could go to a camping shop ;)
Lined and put tank in then made up some Alu straps to hold it down for when doing some duke jumps
<a href="http://s73.photobucket.com/user/autofet ... 3.jpg.html" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... mor9y3.jpg" border="0" alt=" photo 0944009C-2BFA-4779-BD07-D4737FE84AEB_zpskqmor9y3.jpg"></a>
<a href="http://s73.photobucket.com/user/autofet ... y.jpg.html" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... pifu5y.jpg" border="0" alt=" photo FBFD0B18-944E-4328-8B55-11654BCF6E26_zpsnlpifu5y.jpg"></a>
<a href="http://s73.photobucket.com/user/autofet ... b.jpg.html" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... 7li1cb.jpg" border="0" alt=" photo 21896159-944A-4658-9B9F-7C47D6315D38_zpsbm7li1cb.jpg"></a>
<a href="http://s73.photobucket.com/user/autofet ... o.jpg.html" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... 7zma0o.jpg" border="0" alt=" photo EA4D9A9B-C9EF-4987-9ED3-9DE3CA15F453_zpsdb7zma0o.jpg"></a>
<a href="http://s73.photobucket.com/user/autofet ... b.jpg.html" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... dn6txb.jpg" border="0" alt=" photo 227FC48F-E598-42F2-9212-7B27CE31B3F9_zpshrdn6txb.jpg"></a>
<a href="http://s73.photobucket.com/user/autofet ... 0.jpg.html" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... rvakx0.jpg" border="0" alt=" photo 9D6CB205-3089-4B7D-8C87-3DF6C129DE7F_zpsi9rvakx0.jpg"></a>
<a href="http://s73.photobucket.com/user/autofet ... s.jpg.html" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... ajjqks.jpg" border="0" alt=" photo F46271E1-6A3F-4B10-BF46-191CC5BA0BAB_zpsjrajjqks.jpg"></a>
<a href="http://s73.photobucket.com/user/autofet ... p.jpg.html" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... mfy8vp.jpg" border="0" alt=" photo 1861297A-9EED-43F6-B250-D0229B5F850E_zpsrlmfy8vp.jpg"></a>
<a href="http://s73.photobucket.com/user/autofet ... e.jpg.html" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... vqbtpe.jpg" border="0" alt=" photo 28B87427-5AA7-4049-AAD6-BD332202D48F_zpsu2vqbtpe.jpg"></a>
<a href="http://s73.photobucket.com/user/autofet ... 3.jpg.html" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... qe2us3.jpg" border="0" alt=" photo BEAD8E13-E740-4928-A266-0CDBE946274B_zpskeqe2us3.jpg"></a>
Your doing some great stuff Will.
I think you could of come down on weight/ strength of the TPS bracketry & Rod ends, it doesn't need much effort to alter the TPS position.
Must of taken a while to get the ratios right ;)
I saw this lot for real the other day. Really clever stuff :thumbright:
The dash wiring looks truly terrifying up close!
Do you have foam between the tank and the straps mate, can't tell from the pics?
Yes mark the angle :runaway!:
Have a little bit of padded double sided tape between tank and braket :thumbright:
Next I had a braket machined up to hold my huge fuel reg.
It's boost reference so will increase fuel pressure at a 1:1 ratio to inlet Mainfold pressure.
Polished up and nice and close to fuel rails
<a href="http://s73.photobucket.com/user/autofet ... o.jpg.html" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... 8u6tgo.jpg" border="0" alt=" photo B4330052-39DE-4FA1-93B3-F2A5894567AE_zpsep8u6tgo.jpg"></a>
<a href="http://s73.photobucket.com/user/autofet ... 9.jpg.html" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... zo3la9.jpg" border="0" alt=" photo D8F3C3CD-1D0F-4905-922C-19C9A0F9AAE3_zpspwzo3la9.jpg"></a>
<a href="http://s73.photobucket.com/user/autofet ... a.jpg.html" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... ejoj5a.jpg" border="0" alt=" photo 524A1840-D81B-4E82-A7D5-23CEF3B98AB5_zpsfaejoj5a.jpg"></a>
<a href="http://s73.photobucket.com/user/autofet ... r.jpg.html" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... fhbsor.jpg" border="0" alt=" photo 74025108-5340-49F2-AE35-AEEC5F40CC83_zpsclfhbsor.jpg"></a>
<a href="http://s73.photobucket.com/user/autofet ... s.jpg.html" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... apr8qs.jpg" border="0" alt=" photo 7088E7BA-6060-4D16-91C5-64B9E5D7049A_zps1tapr8qs.jpg"></a>
sublimemike
Post by sublimemike »
Betcha just itching to fire her up . Lovely work as always. I look forward to seeing her in the flesh. :)
Mmmm... shiiiiinyyyy 8-)
Will,
I am not saying you will have a problem & most likely all will be OK. But it's not good practise to solid mount regulators.
Thanks mark I see where you coming from its a piston in a bush that won't like being rattled by engine will see how we get on with it can always change later.
Since I am mounting it solid I can use hardline to feed my fuel rails.
<a href="http://s73.photobucket.com/user/autofet ... j.jpg.html" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... ddj6rj.jpg" border="0" alt=" photo F762BD23-87B7-45CC-A59A-D622E47256CF_zps9uddj6rj.jpg"></a>
<a href="http://s73.photobucket.com/user/autofet ... y.jpg.html" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... ag4rgy.jpg" border="0" alt=" photo BB083298-4172-4AFD-A121-6FC76D416877_zpshrag4rgy.jpg"></a>
<a href="http://s73.photobucket.com/user/autofet ... i.jpg.html" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... ix8t2i.jpg" border="0" alt=" photo A2C283D6-4654-492F-9175-C7282E83052B_zpsnhix8t2i.jpg"></a>
<a href="http://s73.photobucket.com/user/autofet ... 7.jpg.html" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... vfvz77.jpg" border="0" alt=" photo 090DEE19-C6D3-4D2C-8F1B-4097DE1BCA35_zpsaevfvz77.jpg"></a>
<a href="http://s73.photobucket.com/user/autofet ... q.jpg.html" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... dubi4q.jpg" border="0" alt=" photo 64DE5278-DD8C-46AC-ABFB-48CF9626AA65_zpsemdubi4q.jpg"></a>
Guy
Post by Guy »
That must be tall if you need a step ladder to reach up to the injector hat :lol:
I know it was discussed previously, but you are regulating after the rails ?
You want full pressure going to the fuel rails....
Don't worry, I must get better glasses ;)
mopar_mark wrote:I know it was discussed previously, but you are regulating after the rails ?
http://www.moparuk.com/forums/viewtopic ... 543#555543
Well I would love to tell you all stories of making inlet runners longer and the quantum leap phenomenal.
But it's. Basically a 4inch penis enlarger that will make my blower/EFI setup
Stick out the bonnet another 4inches :geek: :geek: :geek:
<a href="http://s73.photobucket.com/user/autofet ... u.jpg.html" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... 1ig5ru.jpg" border="0" alt=" photo 5E1F0C6A-AAE8-431B-BE54-164B090D2BEE_zpsir1ig5ru.jpg"></a>
<a href="http://s73.photobucket.com/user/autofet ... 4.jpg.html" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... hgmrc4.jpg" border="0" alt=" photo 5EA7EEB5-2063-4027-BD89-450505BDF233_zpsbdhgmrc4.jpg"></a>
<a href="http://s73.photobucket.com/user/autofet ... z.jpg.html" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... 64troz.jpg" border="0" alt=" photo 62EF9590-E484-48F7-8E98-5A7F3E1C6FA8_zpslb64troz.jpg"></a>
<a href="http://s73.photobucket.com/user/autofet ... 5.jpg.html" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... aiuze5.jpg" border="0" alt=" photo B5A9C2B6-4285-4265-988A-92007C15E304_zpszdaiuze5.jpg"></a>
<a href="http://s73.photobucket.com/user/autofet ... 1.jpg.html" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... omrcq1.jpg" border="0" alt=" photo 6D752CE4-9A9F-4681-80ED-6E8F3F129A9D_zpshyomrcq1.jpg"></a>
<a href="http://s73.photobucket.com/user/autofet ... 0.jpg.html" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... zstes0.jpg" border="0" alt=" photo EF93C4CB-7CD8-4709-B092-243F8D30AEBB_zpscxzstes0.jpg"></a>
Yep, you are definitely going to have to cut a big hole for that one, and drive wearing Stilts with a cushion on the seat!!!
