Dave Robsons Challenger R/T
super looking car dave,the dash looks the biz 8-) 8-) 8-)
Mick70RR wrote:Looks great Dave. Did you refit the overdrive switch and lights in your own bracket, and what's the other switches for?
Yes. Made a bracket.
The rocker switches are windscreen fan on/off and speed setting. No heater of course but even cold air up the screen will help clear it if it starts to mist up. I used to have them labled but can't get letraset the right size these days.
Mick70RR
Post by Mick70RR »
It's a brave man who drives a car in this country without a heater. Switches look nice, maybe get hold of one of those dyno machines for the text, been a few years since I used letroset.
Mick70RR
Post by Mick70RR »
Mick70RR wrote:It's a brave man who drives a car in this country without a heater.
Come for a ride in mine then, it's more of a case of a 'brave man that drives without AC' :D :D
Jeff
Post by Jeff »
might be able to help you there dave :thumbright:
Philth
Post by Philth »
Superb work, Dave! Your Challenger has the perfect 'stance'.
1973 Dodge Challenger
MMA 616
Jon Connolly
Post by Jon Connolly »
Yep well done
Top car, lovely workmanship and attention to detail
Richard
Post by Richard »
That looks great Dave, love that trans am look. You've got a lot to be proud of there, I know it's not been easy for you recently.
Lovely piece of motor you have there Dave. A credit to you. Always liked that car. Tough as a pit bull with a flick knife. Got the best possible engine too. 440+6's rock :thumbright: :thumbright:
Richard wrote:That looks great Dave, love that trans am look. You've got a lot to be proud of there, I know it's not been easy for you recently.
Praise indeed from a master car builder! :notworthy:
Update on tuning.
I have done a series of tuning tests now.
At idle (in gear @ 800rpm) I currently have;
14.5 AF ratio and 8 inches of vacuum.
Driving in top gear at 2000rpm (only on the center carb) I have 13.7 to 14.0 A/F ratio and 16 inches of vacuum.
At 4000rpm (outer carbs should be open some) I have 13.2-13.4 A/F ratio and around 17-18 inches of vacuum.
Plans next are to go up one jet size on the center carb, add a fraction more initial timing (going to try 19 initial and 36 total), go a touch richer on the idle mixture, and change from a 4.5 power valve to a 6.5.
Blimey Dave, that;'s probably better than 75% of the cars currently on the road already...very impressive :thumbright:
It is much easier with the data recorder and wideband sensor. :thumbright:
I did have 12.7:1 ratio on the center carb and dropped two jet sizes to get 13.7 for better mileage and cleaner plugs at low rpms around town. But with the outer carbs not being quite rich enough i will go one jet up to even things out a little more. I would like to get around 13.1 with all carbs open and don't really want to drill out the secondary plates any more.
Jim
Post by Jim »
Top work Dave!
Tough stance. That car is just right.
I look forward to seeing it again at the Nat's.
