Blue's stroker build
Philth
Post by Philth »
Nice work Blue! You certainly don't hang around....!
If you need a hand with anything, or anything trodden on/kicked accidentally, give me a bell - it's a quick 30-40 minutes around the M25 for me now I know the way to your workshop without a map. Wouldn't mind a 'nose' anyway! Hang on - M25 = quick? Hmmm....
1973 Dodge Challenger
MMA 616
Fantastic Blue...look forward to catchin those wheels up :thumbright:
Thanks guys, the plan is to have the motor done for the HRD's, we'll see how that pans out. Phil, I might well be needing your assistance for fire up and cam break in, I don't really want to do that on my own...
Philth
Post by Philth »
I'm there :D
MMA 616
MrNorm
Post by MrNorm »
Blue wrote:Thanks guys, the plan is to have the motor done for the HRD's, we'll see how that pans out. Phil, I might well be needing your assistance for fire up and cam break in, I don't really want to do that on my own...
Well if you need another pair of hands/eyes during the break-in let me know......two helpers recommended :D http://www.moparts.org/Tech/Archive/motor/22.html
TrevD
Post by TrevD »
Blue, remind me to drop a stat housing off to you , that one dosnt do much for the asthetics :D
too much is never enough
Nice sump Blue- you've certainly made the most of what space you have!
Wahey! You see that's what happens when Blue thinks he's not going fast enough!
Top work on that sump, looks great! :thumbright:
Yep , saw it today , top work goin on. :thumbright:
Thanks for the heads up John , saved me a few $$$$$$$$ too.
John , i think the mod you carried out on the lifter valley was awesome , think i'm gonna follow in yer footsteps on the 440 while it's appart.
You gotta start shareing some of those tricks. :D
Again , heads up on the attention to detail.
Ok, finally got the time to get on with it. Installed the cam bearings, I found it nigh on impossible to get all the oil holes lined up perfectly, even using the proper installation tool. I used a small 12" needle file to get up the galleries and carefully open up the bearings to match the galleries, job done.
Next job, fit the crank, this is an ultralight which is a good deal lighter than a stock crank. All aftermarket cranks have a radius where the journal meets the throw, it is stronger that way. Stock cranks are undercut at that point for cheapness. The normal trick is to use chamfered bearings, but there are none available for the 400 block.
So, now he fun starts, 440 Source say the standard style bearing will normally fit, but you need to check and clearance if needed. I dropped it in and nipped the main studs up and turned it over a couple of times, it was well tight. Bad picture, but you can see the shiny marks on the edge of the bearing where it's contacting the crank radius. I scraped the edge of the bearings with a Stanley knife to give a 45 degree chamfer. I won't bore you with the fine details, but it took 6 hours, crank out 4 times, cleaning, scraping, blah blah to get it right. Crank will now turn by hand. Start getting the pistons in tomorrow, here's one of the I beam rods.
Rogue Trooper
Post by Rogue Trooper »
Looking good Blue, great thread 8-)
1934 Coupe
1954 F100
1972 Norton Commando Fastback
Your Mum Says Hi.
Mopar a God amongst insects.
Mick70RR
Post by Mick70RR »
Them parts look too nice to thrash, keep the pictures coming.
