35th Gary's Picnic---Yanks Weekend
Sorry to hear your woes Mick. I cant advise on your issue, but can say I heard nothing but excellent feedback about Morell lifters...
Mick70RR
Post by Mick70RR »
mopar_mark wrote:Sorry to hear your woes Mick. I cant advise on your issue, but can say I heard nothing but excellent feedback about Morell lifters...
Thanks Mark.
I noticed tiny air bubbles in the oil on the dipstick after the lifters collapsed. Just wondering if that's causing the problem. I run a 7 quart pan and fill it until the oil is in between the full and add marks. Maybe I have to much oil in the pan and the crank is whipping it up. I might drop that lifter in some oil and see if I can get it to pump up. If it does I may give them another go and run less oil.
Nice to meet some of you and thanks for your advice on my car.
On its first outing showed a few signs, small leak, battery not charging anymore, but at least it got there and back.
Work to be done.
challenger wrote:got a new PB 11.95@114mph
Brilliant! Well done mate. :thumbright:
Mick70RR wrote:Not sure what's causing this.
Oil too thin for the engine?
I ask because I had this problem when I first got my Challenger. If the engine got to a higher temp than normal the tappets started to collapse. Letting the engine cool for a half hour used to cure it. But changing to a heavier oil cured it for good.
AllKiller
Post by AllKiller »
Well done Jim...knew it was in there :thumbright:
John S get yer hair cut there another 10th there :lol:
ALL KILLER NO FILLER
AllKiller
Post by AllKiller »
Mick with a bigger stroker crank you need to move the oil even further away...best way is to drop the sump and measure the amount and level and adjust accordingly by drilling a little hole on the dip stick for the new full level.
I think its still too much from what you have said hence the whipping oil effect....which may have caused the lifter to collapse
Do you have a windage tray ?
It doesn't look like it was up to the usual standard, was the turnout of rods low as well?
Actually, I've just checked out UKDRN and Yawning Cat photography and it looks like there was a fir bit of action, but overall a bit quiet...
John
Post by John »
Ivor wrote:It doesn't look like it was up to the usual standard, was the turnout of rods low as well?
There was no shortage of turnouts Ivor, there was even toilet roll theft from the ladies toilets announced :shock:
Now passed customs.
Now on route.
Now in posession.
Now costing me sh*t loads.
Thanks John, that puts everything into perspective! :D
If it hadn't been for the murdercycles, the VW's and the Gasser circus there would have been tumbleweed blowing through the place on Friday & Sat, picked up a bit on Sunday. In general a very low turnout on previous years.
Then it serves you lot right :roll: :roll: :roll: You should have all come to "BROOKLANDS" :thumbright: :thumbright: :thumbright:
AllKiller
Post by AllKiller »
Agreed :D
Don
Post by Don »
[quote="R.RUNNER"]Then it serves you lot right :roll: :roll: :roll: You should have all come to "BROOKLANDS" :thumbright: :thumbright: :thumbright:
Yeah but where were you hiding all day Andy, saw your car, saw JC and his missus, but no Mr. "Runner" :P :P :P
witorque
Post by witorque »
We did make Brooklands, left at 3 pm, got to Shakey at 5 pm
Brooklands was the better show, Shakey was maybe 20% full on the Monday compared to the hot rod drags. Good if you wanted to get a lot of track time though. A tailwind was helping times on Monday
335 mile round trip, 1.75 tanks of fuel
ChrisWitor
