I am starting to think that you are Barking - but in a nice way - and very talented.
octanejunkie
Post by octanejunkie »
Remarkable... Ambitious and a bit crazy, but remarkable! :thumbright:
Bozwell
Post by Bozwell »
i gave up on the expanding foam idea. in some places it stuck and in others it didn't. probably would get there eventually but got bored. cleaned it off and going to layer it with vinyl to build up some areas, then a full layer of thin foam then a last layer of vinyl over that.
Bozwell
Post by Bozwell »
not an easy thing to cover but didn't come out too bad.
Looks okay to me
Bozwell
Post by Bozwell »
restoring the plastic trims now. I have some Black and Red pin stripe tape coming to try to see which colour I prefer. probably be Red to break up the Grey/Blackness of the interior. then lacquer to seal. the faux chrome is aluminium tape polished.
That looks pretty "Factory", very good!
That's some nice work going on there :thumbright:
“It’s good enough for Nancy”
Bozwell
Post by Bozwell »
cheers
decided red wouldn't look quite right.
Bozwell
Post by Bozwell »
steering wheel to restore next.
possibly bulk head this weekend.
Most impressive, Mr.Bond!
Bozwell
Post by Bozwell »
Apologies if you've already explained this but, what happens to the 4 speed hump in the tunnel when you go RHD?
Grow a longer left arm or are you going auto?
Dash lloks great btw.
Bozwell
Post by Bozwell »
lever just needs a simple tweak. which I have already done.
Looks like it came out of the factory that way! Lucky that the design of the dash has allowed you to swap trim across rather than having to make new pieces. What silver did you use to paint the trim? it has just the right finish.
