Johnny's Dart repairs
Johnny Dart
Post by Johnny Dart »
Had a play with the exhaust X pipe at lunch today. I had to cut the X pipe up because my Dart has already got a 2 pipe system built by someone else, and the distance between the 2 pipes is bigger than the standard X pipe.
I'll have a weld up tomorrow lunch time.
Oxygen sensor will go in the X pipe .
Johnny Dart
Did a bit more exhaust this evening.
Cut off old nasty exhaust pipes
Tacked and checked for fit
welderized
Test fit, just need to make up the rest of system.
I would like to go for over axle pipes. Does anyone know where to get some in the UK ?
Good work matey.
I think you can get various bends of pipe on E bay. So I was told ?
Johnny Dart
Mossy68 wrote:Good work matey.
Yes . I have had a look tonight, I can get 2 1/2 inch over axle pipe, but they only have 1 left ...... :roll:
Johnny Dart
Finished off the X pipe today, and fitted the oxygen sensor boss.
Waiting for some welding bends and clamps to come tomorrow.
Bozwell
Post by Bozwell »
Dave999 wrote:on these axles you need a case spreader to put the blasted things back in without risking destroying the shims
you can use a large G clamp and squeeze the axle case top to bottom to spread the casing to fit the diff :thumbright:
yeah but thats a bit scary
or i guess prop it between two tressles and invite a fat lass round for a sit down :thumbright:
just strap her belt round the pinion snubber and delve in from beneath
Johnny Dart
I've done a bit more exhaust tonight.
Just need to source some mounts, and hang it right.
Sounds like a V8 now , rather than 2, 4 cylinder engines. And runs much smoother :thumbright:
Will this make the NATS JD?
Would like to hear the new exhaust.......though i've been converted (in taste) from X pipe to individual pipes (sound preference for me)!
Coming on a treat!! :thumbright:
Johnny Dart
Dave81 wrote:Will this make the NATS JD?
I doubt I'll make the Nats this year.Although I've done quite a bit of work on the Dart, I still need to do loads more to make it how I want it.
Now the weather is getting better, I have lots to do on my property, that I couldn't do last year because of the rain.
And that may slow up the progress on the dart.I hope not.
Personal choice , pipes, I think. But I also wanted to stick the oxygen sensor to be able to sense ave mix of both banks.
Bozwell
Post by Bozwell »
Dave81 wrote:though i've been converted (in taste) from X pipe to individual pipes (sound preference for me)!
Cross over pipe explained :thumbright:
Johnny Dart
The benefit of the X pipe for me,other than the oxy sensor, is that it runs smoother, its quieter, and should be more responsive , as one bank of cylinders, help suck out the other bank ( scavenge effect ) :)
Didnt go the over axle route in the end then Johnny
Understand the difference and have done a load of research back in the old days, scavenging, pulses, backpressure etc. As JD says its all personal pref. Quite like the dual non crossover setup i have on my car currently. Sounds very different to H or X setups for the reasons explained.
Johnny Dart
Mossy68 wrote:Didnt go the over axle route in the end then Johnny
I still want to , but I couldn't get 2 Jetex over axle pipes in 2 1/2 inch bore.
I contacted the seller, and they had no lead time.
So I thought I would stick with the side exit, but do it properly, and I can always take off the side exit at the clamp ,and make up the 2 over axle bits later on
