Dave Robsons Challenger R/T
- Dave-R
Seal-Up or K-Seal®?
What is the difference between Seal-Up and K-Seal®?
Seal-Up is the original cooling system formula and is based on Sodium Silicate technology. This is very effective at sealing leaks throughout the cooling system but it has one drawback. If Seal-Up mixes with antifreeze and is heated then a reaction can occur leading to coagulation of the compounds in the cooling system and potentially causing blockages. As a result it is essential that the system is drained before and after treatment (as per the instructions on the product). It is not necessary to use any special flushing products but some users like to run water through the system after draining it.
K-Seal® is a newer formula which has proved to be as effective as Seal-Up but has the added advantage of being compatible with all known types of antifreeze. As a result the product can be added directly to the cooling system without any special preparation. It can even be used as a preventative additive where no problems are present.
We continue to stock both products because Seal-Up still has an excellent reputation and loyal customer base with the trade. K-Seal® is now by far our most succesful product and has become popular with the general public, trade and many enthusiasts clubs.
I have to admit, that one is new to me! The stuff I used was called bond something or other, I just poured it into the waterways, rotated it about for good coverage and let the excess drip out.
I can't remember whether or not it went into the oven for curing, but it never leaked or pressurised the cooling system again!
- latil
Devcon is a possibillity,though if the head is porous,not cracked it won't be so easy,whereas the Kalimex is a "seek and block" product. I think RS do most Devcon products,got our last cold casting urethane there.
I have used the k seal on 2 applications. First one was a weeping head gasket, into number 4 cylinder on my cavalier. The 2nd one was on my motorhome with the 360 in, the timing cover gasket was weeping down the front of the engine, it had been like that for 10 years and it sorted that one out too. ANd my brother used it in his heater matrix on his cavalier. SO it's got to be worth a go.Dave wrote:That K-Seal sounds like it is worth a try at least. If it works I will be not just over the moon, I will be way way way over the moon.
challenger
i used k.seal on the last pair of (906) heads i had on but that was after it had been weldedDave wrote:That K-Seal sounds like it is worth a try at least. If it works I will be not just over the moon, I will be way way way over the moon.
keep it mopar !
