Blue's Barracuda
- pete walton
Re: Blue's Barracuda
good luck for the weekend Blue
Cheers Pete, forecast is lousy but you never know…
Failed miserably when one of the rear shoes fell apart at the 11th hour. So, on with what I should have been doing 6 months ago…
- IMG_2218.jpeg (190.11 KiB) Viewed 8868 times
Bit of cheap 7mm adhesive chrome strip off eBay finishes off the head rest nicely.
- IMG_2219.jpeg (113.16 KiB) Viewed 8868 times
- Stu
That looks tidy!
That works
Today’s job, adjustable front suspension limiters and Hotchkis steering arms. Being able to adjust front suspension travel is one way of controlling wheel stands, plus it stops the rod ends on the steering arms from running out of travel.
- IMG_2221.jpeg (175.28 KiB) Viewed 8799 times
- IMG_2220.jpeg (163.04 KiB) Viewed 8799 times
- IMG_2223.jpeg (206.3 KiB) Viewed 8799 times
- IMG_2224.jpeg (192.71 KiB) Viewed 8799 times
Those rose jointed arms look trick! Any issue with them rusting?
Not seen stuff like this rust but then the car never really sees bad weather, I will fit some boots though to keep dirt out.
sublimemike
All the right trick stuff to chip away at those 1/10th's. Nice Jon.
Ha, I should stop mucking about and bolt in some more horsepower!
hp in a bottle?Blue wrote: Sun May 12, 24 7:58 pm Ha, I should stop mucking about and bolt in some more horsepower!
Not legal in Super stock Neil, I need a hardware upgrade, it’s in the pipeline.
ooh! big block? or even stroker big block?
No I’m done with big blocks, I really like stroker small blocks. I have new heads and intake to fit which should add a bit more HP.
