Mathematical Question
One for all you Vordermans! What sort of difference to a Compression Ratio if the compressed thickness of the head gasket is 5 thou thinner. (3.91" bore)
Provided the reciprocating assemblies stay ecxactly the same it will go upsidaisy.
Iit will go up, but not much - a lot depends on bore size. The Hemi made .2 CR difference for a 11 thou change in gasket.
Thanks! :thumbright:
Hemi was 4.3750 bore....so more impact thna yours.
I've looked closely at the relationship between the thickness of the head gasket in direct comparison to the effect that has on compression ratio and performed an experiment to make a calculation on the possible increase in efficiency and therefore, performance.
By taking a close look at the configuration of heterodyne interferometry with the fiberoptic sensor. A frequency stabilized He-Ne laser, with a wavelength &#955; of 632.8 nm and an output power of 1 mW, provides a linear polarized beam for the measurements. The AOM system for heterodyne interferometry produces two beams. In this experiment, the frequency of the first beam is shifted by 80.100MHz, and that of the second by 80.125 MHz.
The stability of our AOM is within 0.02ppm.These beams meet at the polarized beam splitter and create a beat frequency of 25.0 kHz. After the polarized beam splitter, the beam is split into two by the half mirror.
One beam is detected by a photo-transistor as a reference signal; the other is used for modified Michelson interferometry. The reference signal beam passes outside the combustion chamber and is reflected by a mirror.
The beam used for modified Michelson interferometry passes through the test section, is reflected by a mirror, and then passes back through the test section again.
The result was a drastically improved flame front in relationship to the .00355479 % increase in compression ratio, by using the thinner gasket on the small black Mopar engine.
What is the standard thickness of the head gasket?
Time to up the medication dosage again Ivor; or should I say "Igor"????
The day I'm having Pete, I need a very large glass of medication!
Ivor, my boss tells me that an engineer should be able to do for a quid, what any old fool can do for a fiver.
Surely you could have just said " the compression goes up" Kev didnt ask "by how much, why, and how did you know" :lol: :lol: :lol: :lol: :D
You are a one. :D
Not sure what sort of answer Kev wanted but the actual amount would be different from engine to engine.
Since I am still officially a student engineer this is free ;)
Assuming:
- 3.91" Bore
- 3.31" Stroke
- 0.039" Compressed gasket height
- 4.180" Gasket bore
- 64.5cc Chamber
Your compression ratio will be 9.97:1
If the gasket is 5 thou thinner (compressed) then your compression ratio will be 10.1:1.
I would be more worried about the crevice between the head and deck created by the oversized bore of the gasket though. That is a nice area for burnt gases to collect and then spoil the fresh mixture coming in.
Incidentally if you could match a gasket of exactly 3.91" bore then your compression would be 10.1 at the standard height and go up to 10.2 for the 5 thou thinner gasket.
Great answer, James! The standard Fel Pro is 0.050" the Rol Extreme is 0.045". Know what you mean about the oversize gasket :roll: Curse of the 318! :?
Thats interesting Bratfink, I went down to .027 (0.29?) from Felpro standard head thickness, wondering what effect it would have on compression.
Although Kev asked about the difference in compression rates, james, surely to assess actual compression rates you would have to know if the block was decked and whether the piston was flat/domed/had cutouts?
You can tell i'm on summer hols... :help:
