wheels n tyres for dart
Jeff
Post by Jeff »
So what size wheel and tyres am I going to be able to fit under this 69 Dart?
Should I go 14 or 15 inch?
Doubt you'll get wider than a 7" on the back. Go for 15" so you have a good selection of tyre sizes, not much choice in 14" these days. Assuming it is all stock you"ll be needing wheels in 4" PCD, good luck with that, they are few and far between....
Jeff
Post by Jeff »
I found someone that does quite a lot of 4" pattern Blue.
They aint cheap though.
Re-drill those hubs!!
I have a nice set of Weld draglites sitting here ;)
Jeff
Post by Jeff »
tell me more Pete!! I am interested!
Jon
Post by Jon »
who does a lot of 4" pattern wheels Jeff?
TrevD
Post by TrevD »
if you need the hubs sorting let me know ;)
too much is never enough
Jeff
Post by Jeff »
I may well do Trev.
Jeff
Post by Jeff »
Jon... go to http://www.stocktonwheel.com/mopar.php good range there.. I like the big steel wheels!
BUDGIE
Post by BUDGIE »
I have.........
1 x set Mint Cragars Mint Goodrich....................£500
1 x set Mint mirror polished Wolfrace...................£375
1 x set new ARE Torque Thrust D's.......................£700
1 x set new OE magnum 500s new Goodrich......£500
Jon
Post by Jon »
cheers Jeff
